^^^ Gaucho: That's a very disappointing question since it strongly suggests that you are using a fake cable!
So - the only correct answer has to be to either update the software to Ross-Tech's latest version (which is ver16.8.4) - if you are using a genuine RT cable. Otherwise - throw the fake cable into the rubbish bin (because that's where it belongs) and stop supporting the trade of Intellectual-Property theft! Buyers of fake cables are as complicit as are sellers in this fraud!
Hello guys,
Today after fiddling a little bit with my 2016 Seat Ibiza TDI DSG I was able to SUCCESSFULLY and PERMANENTLY disable Start-Stop system.
Note: This solutions is not the vwwatercooled.com temperature or voltage method!!! Despite their effectiveness, I don't want to risk my car electronics with such "hacks".
Note 2: This is tried on 2016 Seat Ibiza, but the Skoda Fabia/Octavia and other VAG's should be virtually the same.
Note 3: Please carry out any modifications and coding AT YOUR OWN RISK!!!. I will not be held responsible for any damage of the vehicle and I am just giving you the steps.
The tools needed:
VCDS Release 16.8.3 or higher version + compatible OBD II CAN Enabled cable. (You can buy them @Ross-Tech)
The steps to disabling start-stop system:
1. Enter 19-CAN Gateway
2. Click on Coding-07
3. Click on Long Coding Helper
4. Change Byte 3, Bit 2-3 (Drop down menu) from 04 Start/Stop System with Recuperation installed [PR-7L6] to 08 Start/Stop System NOT installed [PR-7L3]
5.Change Byte 4, Bit 0 to 0
6.Change Byte 15, Bit 0 to 0
7. Click on Exit - top left hand corner
8. Click on Do it!
Voila you are done!
I would be really happy if you can report your success stories with Fabia, Octavia and other last gen VAG cars. Also I would be happy to post it to other forums, by citing my nick as a credit @kickdown
Any questions I am on site!![]()
The only 'risk' with the temperature method as far as I can tell is that if you car ever actually is >255 degrees C, your Start/Stop system will function. But nice to have another option.
Hopefully one day we find out a code change that leaves the system disabled by default but operational on a press of the button. Fortunately the location of that button is far less annoying in the Audi than in the Golf (imo).
kickdown: well done - just so I'm clear, have you tried this successfully on a Golf Mk7? Second question - what about all the adaptation channels in the other control modules (including the CAN Gateway) that were set as if SS was active?? I've not done an exhaustive search, but here are some that I found easily (I'm sure there will be others).
Third question- what the SS settings for the coding on the other control modules - like Byte 8, Bit 4 on the HV AC modue @ address hex 08?
Only risk with temperature/voltage method is the "tell" on the MFD every time that the car stops (the dreaded "A" symbol with a slash!)
Hopefully kickdown's method is good on a mk7 - and hopefully someone with a mk7 will confirm its fault-free operation (with all systems running)!!
Narrh......... best way is to install my easy-to-build Automatic SS kill switch! It hasn't missed a beat in over 12 months operation - every time ignition is turned-on, SS is automatically turned off - no hassles, no mess, no coding changes - just blissfully ignore the entire issue of SS!
@hprs230 we should give this a crack !
MY16 Octavia VRS Wagon, DSG, Race blue, Tech pack, Comfort pack, Black Pack, 19's, Sunroof, Electric Tailgate
Airbox mod, VW Racing Filter, TMD, Elbow, Ramair Pipe, GFB DV+, VCDS mods, Superpro adjustable rear sway bar, Superpro end links, Whiteline front sway bar links, Whiteline LCA bush Kit, Bilstein B14 coilovers, HPA dog bone mount & arm, 42DD oil catch can, Burger wheel spacers, CTS downpipe 200 cel cat, 2,5" exhaust , twin out. Super Skoda eyelids & front splitter, Tuned by BPS 228kw atw, Dsg tune,
Hello guys.
New release vcds 17 and now new option - official disable fu!!!ing ss on seat ibiza 2017 1.0 tsi dsg
by_rom: Alas, there ain't nothing new about this facility -it's not something that was introduced in "New release vcds 17 and now new option".
One of our colleagues here had this to report about the function on 3rd January 2015 in response to my suggestion that it might be a useful alternate to both the "temperature" and "voltage" methods for disabling SS (see post #22 of this thread)
