Originally Posted by
drzikzak
Hello guys!
My name is Alex, I'm 28 and from Austria...aside from being a student of medicine, I'm a car-guy and spend every second of my leisure time on cars and technical stuff in context with that.
So I've helped myself to a VCDS interface to diagnose and code cars as I've got a lot of friends driving VAG vehicles.
Last time I came across a Golf VII 1.6 TDI of a friend of mine....he suffers from the start/stop system always shutting down the car at traffic lights and stop & go traffic, which is quite an everyday sight here.
I got myself involved and tried different ways to shut down the stop&go behaviour...but none of these suceeded...
What I've tried:
Change coding of ECU (Start&Stop not installed or disabled - don't know what it says exactly), coding of the on-board supply controlling unit (disable Start&Stop) and also tried to find adaptation bytes for "start/stop working temperature" or "voltage"...which I couldn't find at all....
Asking the German forum for advice didn't give me more than a locked topic in the forum and a friendly message that no one would explain to me how I could threaten my car's operating licence by disabling the start&stop system....
So this led me to this forum...I hope you will be able to help me getting this task solved...
Thanks in advance!
Regards,
Alex
Alex: Hallo und herzlich willkommen im Forum
It's good to meet someone (your friend) who despises Start Stop (SS) as much as me (and I hate it with a vengeance)! I've said before on numerous forums that IMO it's the most dangerous facility in a motor vehicle. I'm not particularly into conspiracy theories, but if I were, I would view SS as a cunning and sinister "sleeper function" (IMO) - being cleverly disguised as a climate saving feature!
So yes -I urge you to remove the function from your friend's car as quickly as possible!
OK - now to the techo bit! As you have discovered, SS is intimately entwined into lots of control modules on a mk7. On some VAG vehicles there is a "virtual master switch" to disable SS, but I do not believe that this is the case on MQB platform vehicles (I would be very happy to be proven wrong). If you try to disable the facility on one module, an error appears on multiple other modules. Pursuing this approach is the delicious futility of an impossible task - so my suggestion is, don't persevere with this technique!
Instead, I invite you to consider the following two alternatives:First, you could implement the more simple VCDS cable tweak (
HERE). All these tweaks work by tricking the SS system into believing that some aspect of the car isn't able to support switching-off the engine; the temperature method does this by indicating that the temperature is too high and the voltage method does the same thing by indicating that the battery voltage is too low. Unfortunately, when if you implement the VCDS tweak, there will be a "tell" on the MFD whenever the car stops: what happens is that the MFD will display an "A" with a slash. This indicates that SS is active, but that it isn't able to engage because some aspect of the car prohibits the function. If you interrogate this "error", the MENU screen will display the first line in the picture below
Second, you could implement the "physical" solution: the SS auto kill switch. This involves building and installing a simple electronic device that I designed about a year ago. I've been using this device since then and it has never failed - every time that I turn-on the ignition, 5 seconds later SS is automatically disabled and I can re-engage the facility if I want later in the journey - not that I have ever done this! There is no "MFD tell" with this solution -all that the driver sees is the illumination of the LED indicator on the SS button on the center console. The instructions for my kill-switch are
HERE.
