Will it throw up lights on the dash?
Just disconnect the battery monitor unit plug on the battery earth lead....VDUB...
VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150BRISBANE / GOLD COAST
'07 Transporter 1.9 TDI
'01 Beetle 2.0
MY 21 T Cross 85TSI Life| Makena Turquoise | Driver Assist Package |
Mods: VCDS tweaks |
Last edited by AdamD; 26-02-2014 at 08:24 AM. Reason: Shifted VCDS content to VCDS thread
Thanks guys, have turned off the stop start and works well...
Any body found the coding to get the traffic or tmc working ... Can't find any thing anywhere...
Also those links posted above are great...
2019 MY19 Mini JCW Hatch
2016 Holden Astra RSV - Waiting for New Golf
Yep, that thread hasn't had much visibility so I've moved it into the Mk7 section for now, and shifted your post into it here:
http://www.vwwatercooled.com.au/foru...ml#post1033967
(Bear in mind that external links are only of use until a remote site goes down, is edited or otherwise changes to become less useful. It's also more difficult to quote remote references in context, so don't hesitate to post codes and suggestions in the above thread on VWW if appropriate.)
Agreed. If you've got time get a copy of the codes/screenshots on these forums like I did for the Mk6. No-one has yelled at me for doing them
(Just put a thanks/credit link to the source websites at the bottom).
Hi guys
Im desperately trying to turn off start/stop on my caddy. however when i go into adaptation (mine actually says long adaptation) those channels aren't listed at all.
i found some other areas that relate to this under engine, but if i do it via coding, it does nothing, and if it turn it off via engine adaption it just changes the value to active again.
any thoughts??
thanks
