Page 7 of 8 FirstFirst ... 5678 LastLast
Results 61 to 70 of 73
Thread: Disable Stop/start - VCDS tweak
  1. #61
    Apr 2017
    Israel
    2 DV52 Thanks. My apologies. You are right.
  2. #62
    Dec 2016
    brazil
    I can confirme the voltage method works with 12.12 vcds and golf mk7 2014 1.4 TDI.
  3. #63
    Apr 2016
    Perth, WA
    kickdown: well done - just so I'm clear, have you tried this successfully on a Golf Mk7? Second question - what about all the adaptation channels in the other control modules (including the CAN Gateway) that were set as if SS was active?? I've not done an exhaustive search, but here are some that I found easily (I'm sure there will be others).
    Third question- what the SS settings for the coding on the other control modules - like Byte 8, Bit 4 on the HV AC modue @ address hex 08?
    I have tried this and it doesn't stop S/S. There's a few other places where S/S installed is mentioned in long coding so I might try unticking them as well.
  4. #64
    Oct 2017
    Bucharest
    Hello, i have one question. It is possible to set as a default value (when car starts for the first time) the start stop function as disabled (the button light is turn on). I would like to go on this method since are times when i want to use the function so I would not permanently disable the function. Thanks
  5. #65
    Oct 2017
    Bucharest
    forget it as long as i understand the only method is the DV52 method (nice job by the way) or with a special module. I thought that this would be possible with VCDS
  6. #66
    Oct 2016
    Hi all - I have disabled stop/start via the app on obdeleven. Was just wondering if it would be possible to have the stop/start active in eco mode only?
    | 2016 VW Golf R 7 | DSG | Pure White | Leather | Sunroof | Driver Assist | JB4 |
    | 2003 VW Golf SE | Auto | Silver | Sunroof |
    | 2010 VW Golf R 6 | Manual | Leather | ACC | 19s | Black Pack | GIAC Stage 2+ |
  7. #67
    ^^^^^^^^ hmm.......... I'm fairly certain (almost certain) that it's not possible with the VCDS/OBD11/VCP tweaks (both "voltage" and "temperature" methods) to distinguish between "eco" and normal modes.
    Remember that these tweaks are "hacks" really that fool the car into believing that SS shouldn't be engaged - they have absolutely zero sophistication!
    PS: but I'm happy to be proven wrong
  8. #68
    Oct 2016
    Cheers Don, I thought that may be the case - would be a good mod though.
  9. #69
    Sep 2009
    Melbourne - Vic
    I'm amazed that people still try to defeat SSS by tweaking software, paying for OBD dongles etc.
    I installed a custom made "DV52 Device" over two years ago and it has performed without fault and is instantly re-energised by hitting the button.
    The DV52 device simply reverses the logic of the SSS so that it is set to "OFF" on start and can be set back on when required.
    Without doubt the best solution so far.
  10. #70
    Dec 2010
    Quote Originally Posted by jimmyjames View Post
    What is this device and where can I get one? I want to do this on my Arteon. Stop/Start is annoying as fk.
    My car: MY18 Arteon
    My car #2: MY22 Volvo XC40 Pure Electric
    Her car: MY22 Skoda Octavia Limited Edition Wagon
