Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 73
Thread: Disable Stop/start - VCDS tweak
  1. #51
    Quote Originally Posted by gaucho View Post
    can anyone confirm me if I can do that with 12.12 VCDS?
    ^^^ Gaucho: That's a very disappointing question since it strongly suggests that you are using a fake cable!
    So - the only correct answer has to be to either update the software to Ross-Tech's latest version (which is ver16.8.4) - if you are using a genuine RT cable. Otherwise - throw the fake cable into the rubbish bin (because that's where it belongs) and stop supporting the trade of Intellectual-Property theft! Buyers of fake cables are as complicit as are sellers in this fraud!
  2. #52
    Jun 2007
    Sydney, Australia
    Only if you are using Windows XP
    Flipper Dog
    Now - T-Roc R, Audi Q5
  3. #53
    Dec 2016
    Sofia, Bulgaria
    Hello guys,
    Today after fiddling a little bit with my 2016 Seat Ibiza TDI DSG I was able to SUCCESSFULLY and PERMANENTLY disable Start-Stop system.
    Note: This solutions is not the vwwatercooled.com temperature or voltage method!!! Despite their effectiveness, I don't want to risk my car electronics with such "hacks".
    Note 2: This is tried on 2016 Seat Ibiza, but the Skoda Fabia/Octavia and other VAG's should be virtually the same.
    Note 3: Please carry out any modifications and coding AT YOUR OWN RISK!!!. I will not be held responsible for any damage of the vehicle and I am just giving you the steps.
    The tools needed:
    VCDS Release 16.8.3 or higher version + compatible OBD II CAN Enabled cable. (You can buy them @Ross-Tech)
    The steps to disabling start-stop system:
    1. Enter 19-CAN Gateway
    2. Click on Coding-07
    3. Click on Long Coding Helper
    4. Change Byte 3, Bit 2-3 (Drop down menu) from 04 Start/Stop System with Recuperation installed [PR-7L6] to 08 Start/Stop System NOT installed [PR-7L3]
    5.Change Byte 4, Bit 0 to 0
    6.Change Byte 15, Bit 0 to 0
    7. Click on Exit - top left hand corner
    8. Click on Do it!
    Voila you are done!
    I would be really happy if you can report your success stories with Fabia, Octavia and other last gen VAG cars. Also I would be happy to post it to other forums, by citing my nick as a credit @kickdown
    Any questions I am on site!
  4. #54
    Apr 2010
    The only 'risk' with the temperature method as far as I can tell is that if you car ever actually is >255 degrees C, your Start/Stop system will function. But nice to have another option.
    Hopefully one day we find out a code change that leaves the system disabled by default but operational on a press of the button. Fortunately the location of that button is far less annoying in the Audi than in the Golf (imo).
  5. #55
    Quote Originally Posted by kickdown View Post
    Hello guys,
    The tools needed:
    8. Click on Do it!
    Voila you are done!
    kickdown: well done - just so I'm clear, have you tried this successfully on a Golf Mk7? Second question - what about all the adaptation channels in the other control modules (including the CAN Gateway) that were set as if SS was active?? I've not done an exhaustive search, but here are some that I found easily (I'm sure there will be others).
    Third question- what the SS settings for the coding on the other control modules - like Byte 8, Bit 4 on the HV AC modue @ address hex 08?
  6. #56
    Only risk with temperature/voltage method is the "tell" on the MFD every time that the car stops (the dreaded "A" symbol with a slash!)
    Hopefully kickdown's method is good on a mk7 - and hopefully someone with a mk7 will confirm its fault-free operation (with all systems running)!!
    Narrh......... best way is to install my easy-to-build Automatic SS kill switch! It hasn't missed a beat in over 12 months operation - every time ignition is turned-on, SS is automatically turned off - no hassles, no mess, no coding changes - just blissfully ignore the entire issue of SS!
  7. #57
    Dec 2016
    Brisbane Qld
    @hprs230 we should give this a crack !
    MY16 Octavia VRS Wagon, DSG, Race blue, Tech pack, Comfort pack, Black Pack, 19's, Sunroof, Electric Tailgate
    Airbox mod, VW Racing Filter, TMD, Elbow, Ramair Pipe, GFB DV+, VCDS mods, Superpro adjustable rear sway bar, Superpro end links, Whiteline front sway bar links, Whiteline LCA bush Kit, Bilstein B14 coilovers, HPA dog bone mount & arm, 42DD oil catch can, Burger wheel spacers, CTS downpipe 200 cel cat, 2,5" exhaust , twin out. Super Skoda eyelids & front splitter, Tuned by BPS 228kw atw, Dsg tune,
  8. #58
    Apr 2017
    Israel
    Hello guys.
    New release vcds 17 and now new option - official disable fu!!!ing ss on seat ibiza 2017 1.0 tsi dsg
  9. #59
    Quote Originally Posted by by_rom View Post
    Hello guys.
    by_rom: Alas, there ain't nothing new about this facility -it's not something that was introduced in "New release vcds 17 and now new option".
    One of our colleagues here had this to report about the function on 3rd January 2015 in response to my suggestion that it might be a useful alternate to both the "temperature" and "voltage" methods for disabling SS (see post #22 of this thread)
    Quote Originally Posted by jonoz View Post
    Quote Originally Posted by dv52
    Disable Start/Stop (Bluemotion) on Golf mkVII - VCDS tweak
    EDIT: If you have a Mk7 Golf R then you could have Acc/Start Auth. Control module fitted to your car (address 05, HW:5Q0-959-435)
    This controller has only one adaptation channel whose sole function is disabling Stop/Start. The adaptation channel descriptor is Deactivation of start-stop function and default setting is not active. Change this to active
    Hey mate, trying to disable the start-stop but changing the above setting just constantly sets itself back to not active.................................
  10. #60
    Dec 2016
    brazil
    The following two methods can be used to permanently disable Start/Stop (SS) on a Golf mk7:
    (1) Temperature Method, or
    (2) Voltage Method (as an alternative to the Temperature Method)
    From feedback that I have received from forum members (thanks jonoz and Fontana), it appears that the Voltage method is applicable to later "MY" models and the Temperature method can be used on earlier "MY" models (i.e. my13 in my case)
    Before proceeding with this tweak, consideration should be given to any legal and environemtal factors that may result when disabling this facility.
    These instructions were sourced from the Golfmk7.com site. Grateful acknowledgement to the author "Allenlin" who has said that the VCDS tweak was developed on a 103TDI. Allenlin has produced a short video which shows that SS has been disabled (see the link below) I have implemented this tweak on my mkVII, and I can vouch that it works.
    Video: Start/Stop disabled-Golf mkVII
    Allenlin instructions:
    2.Click on Adaptation-10
    3. From drop-down channel list select (1)-Start/Stopp Auntemperaturvorgabe-Minimaltemperatur (it's almost at end of channel list)
    • In New value box, enter 50 (default stored value = -50.0)
    • Click Do it! tab
    • Click Add to Log to save a copy of the change
    4.From drop-down channel list select (2)-Start/Stopp Auntemperaturvorgabe-Maximaltemperatur (it's almost at end of channel list)
    • Click Do it! tab
    (2) Voltage Method (alternative)
    The voltage method is not available to all mk7 models (my own my13 vehicle will not allow access to the Adaptation channel below). However, I have confirmed (by viewing the Adaptation Control Map for Address hex19) that this method is available for the my14 model.
    Instructions
    1. Enter 19-CAN Gateway (see screen shot above)
    2. Click on Adaptation (see screen shot above)
    3. From drop down channel list, select Start/Stop start voltage limit (it's about 60% down the channel list)
    • In New value box, enter 12 (default stored value = 7.6V) Note: forums report that a value greater than 10V will work for this tweak - maximum permissible value =12.1V
    • Click Do it! tab
    This controller has only one adaptation channel whose sole function is disabling Stop/Start. The adaptation channel descriptor is Deactivation of start-stop function and default setting is not active. It may be possible to change this setting to active (untested).
    I've had two replies from forum members about changing the setting on this control module (thanks jonoz and fontana). Both have advised that they were unable to gain access to this module.
    are those still the best method for disabling start-stop in 2014 MK7 1.4 TDI Golfs ?
