Originally Posted by
jonoz
Hey mate, trying to disable the start-stop but changing the above setting just constantly sets itself back to not active. Not sure if it matters but my HW is the same as above but suffixed with an "A"?
Any ideas?
Update: The temperate method also seems to be unable to be modified, I have disabled via the voltage method.
Now, how the hell can I turn off Driving School Mode? I have reversed all the instructed settings but it wont go away!!
Jonoz: Hi, you sound a bit frustrated!
The Acc/Start Auth is a relatively new control module (it's not in my car), so I can't provide much help (unfortunately). Perhaps someone else here that actually has the module in their car can lend some assistance.
Not sure why the temperature method was unable to be modified, because this is the way that I disabled Stop/Start on my car. I used the exact procedure in my post - worked first time without a hitch. Stop/Start has been disabled now on my car for almost 12 months without any problems.
I've had a few PMs from others and there are some posts both here and on the Golfmk7 site from members that have also been able to make the temperature method work. Yours is the first time that I have heard that the temperature method has been unable to be modified. But it sounds like the Voltage method has worked so all good I guess!
OK, now for the other problem of the attempted driving school mode roll-back.
Please provide more details about what happened when you tried to roll-back the settings. For example:
- What RT software version were you using?
- What type cable are you using and is it the same cable that you used to enable Driving School mode?
- Have you looked at the three adaptation channel settings after you finished the roll-back procedure to confirm that the control module actually accepted the changes that you made?
- Have you looked at the CodingLog.txt file in your debug directory to make sure that another adaptation channel wasn't inadvertently selected in the roll-back process?
- I'm not sure that I understand your comment, "it wont go away". If I don't want to use the facility, I simply select another screen using the <, or > tabs. Driving school mode just stays in the background without affecting any other function. Does this work on your Discover media screen?
