Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 45
Thread: Dat batt thread.
amunra Dat batt thread. 27-06-2022, 07:34 PM
Lucas_R Hi friend. This info for... 27-06-2022, 07:58 PM
amunra im more interested in what... 27-06-2022, 08:12 PM
Lucas_R Well the thread I linked to... 27-06-2022, 08:32 PM
amunra with the 20kg saved with the... 27-06-2022, 08:47 PM
MrTony Just replaced my battery in... 28-06-2022, 11:22 AM
amunra sounds like they did a pretty... 28-06-2022, 11:34 AM
MIG Varta every day of the week,... 29-06-2022, 12:08 PM
amunra Sounds Varta (worth it). what... 30-06-2022, 07:54 AM
Micky 32 My father recently changed... 17-08-2022, 08:15 AM
Manaz Wow. Varta definitely had a... 17-08-2022, 08:47 AM
Micky 32 My partner has a Toyota... 17-08-2022, 09:12 PM
Micky 32 My 5 year old Passat with... 17-08-2022, 09:26 PM
Guest001 Sounds like an Irish folktale... 17-08-2022, 12:21 PM
amunra Luck of the irish 18-08-2022, 12:29 AM
MIG Looks to be a 5K0 95 105 K... 30-06-2022, 09:41 AM
amunra big fkn boppa . u charging... 30-06-2022, 11:23 AM
amunra whats everyones experiences... 30-06-2022, 11:25 AM
Lucas_R Like this one? Bosch LN3 AGM... 30-06-2022, 12:24 PM
amunra personally looking at SSB or... 30-06-2022, 12:52 PM
amunra has anyone fit an LN4 sized... 30-06-2022, 12:56 PM
MIG It gets topped out with a... 30-06-2022, 12:23 PM
amunra ok nice work.. maintainace is... 30-06-2022, 12:54 PM
Lucas_R So many of the electronics... 30-06-2022, 03:02 PM
amunra yeh locking ur car door is a... 30-06-2022, 03:11 PM
MrTony This! So important to do! 01-07-2022, 09:59 AM
amunra can anyone in here confirm if... 30-06-2022, 06:04 PM
amunra answer to my own question. ... 30-06-2022, 06:24 PM
amunra just bought an 1030cca 80AH... 01-07-2022, 03:23 PM
Lucas_R So to be clear and... 01-07-2022, 03:35 PM
amunra yeh should be the same one.... 01-07-2022, 03:46 PM
amunra 54283heres a photo of the... 02-07-2022, 01:18 PM
Manaz To assume is to make an ass... 02-07-2022, 01:47 PM
amunra will have to see when it... 02-07-2022, 01:52 PM
Guest001 Wont need bolting down until... 02-07-2022, 01:38 PM
amunra thats imaginative ! 02-07-2022, 01:47 PM
Guest001 And also possible if battery... 03-07-2022, 12:38 PM
petemac110 You are indeed correct. ... 02-07-2022, 01:49 PM
amunra i actually missed this little... 02-07-2022, 02:33 PM
amunra after trying the large batt... 05-07-2022, 08:32 PM
amunra had a crack at modifying my... 06-07-2022, 05:35 PM
amunra Update - Hillbilly can sleep... 21-07-2022, 12:53 PM
amunra this is with the airbox and... 21-07-2022, 06:00 PM
    Quote Originally Posted by amunra View Post
    just bought an 1030cca 80AH SSB battery (larger size).. had a choice between bosch and SSB (same size) for the same price. have read good things about SSB so will give that a go as bosch is a known quantity...
    So to be clear and potentially help out other people in the future, is this what you have purchased?
    Will be interesting to see if the factory tie down bracket still fits. What are you going to do if it doesnt?
    SSB AGM STOP START BATTERY 12V 80AH L315XW175XH190 1030CCA MAINTANENCE FREE - Collier & Miller
    Feb 2015
    Sydney, Australia.
    yeh should be the same one. this is the exact one.
    SSB STOP START AGM SS75TI LEAK PROOF BATTERY 12 VOLT EUROPEAN MERCEDES BMW AUDI 9336054006653 | eBay
    according to the vids the bracket still fits (which surprised me ).. was just going to take the bracket out and dump the batt in without a bracket at first .... until i saw the bracket fits (refer to vid i pasted earlier).
    looks like the tray is designed to fit the larger batt .. it wont be moving anywhere in there when the tray is fully taken up.. they have probably put the bracket as an over caution thing and way to save money on smaller batts from factory
    Feb 2015
    Sydney, Australia.
    Dat batt thread.-20220702_125504-1-jpgheres a photo of the batt tray (albeit upside down)...
    u can see the 3 silver screws towards the end of the tray... the oem bat stops well before the 3rd (closest to end) and needs the bracket to hold it down... the batt is pretty damn heavy to get out of there without the bracket so im assuming a batt that takes up the whole tray is not going to be needing any bolting down
    Apr 2008
    To assume is to make an ass of u and me.
    You don't want a battery that isn't tied down. That's a lot of weight to have deciding it's no longer part of the car and is a free agent to move as its own momentum dictates...
    Nothing to see here...
    Feb 2015
    Sydney, Australia.
    Quote Originally Posted by Manaz View Post
    will have to see when it arrives
    Pacific Paradise QLD
    Wont need bolting down until you have to stop in a big hurry and the battery continues unrestrained till it potentially is slowed down by the head of the kid who walked in front of you. If I remember rightly it is part of a roadworthy to ensure the battery is securely restrained correctly.
    Only a fool would not use the bracket
    Why is it important that automotive batteries in a vehicle are securely held in place with a proper battery clamp?
    Vibration can reduce the life of your car battery, so it is vital that you always use an approved battery clamp to ensure it is properly held down at all times. If not securely fastened, excessive vibration could damage your battery's internal components – creating short circuits and reducing battery life.
    Feb 2015
    Sydney, Australia.
    Wont need bolting down until you have to stop in a big hurry and the battery continues unrestrained till it potentially is slowed down by the head of the kid who walked in front of you..
    thats imaginative !
    thats imaginative !
    And also possible if battery is in engine compartment
    Aug 2021
    It’s a favourite target of the police when issuing defect notices.
    Feb 2015
    Sydney, Australia.
    i actually missed this little bit . couldnt find anything online after seeing this.... actually just want to see how an 80ah batt fits in that tray might need to make something custom or even get a bigger tray if possible.. not sure if itll fit in the engine bay but it might
