Thanks Dutch.
What I have not been able to achieve is a balance where the rubbing is gone but the banging is also gone. It's the only door I get the rubbing from which is quite good. Not sure if that's a temp circumstance of the newness of the car though.
I did note the outer rubber seal that goes along the top and rear of the door glass area is not touching the body at the lower corner. It's like the door is tilted or too far forward. The gap with the front is ok though which also then makes me wonder if the front door alignment is out too (I get slight wind noise there but otherwise it's ok).
The lubrication by the dealer actually helped quiet the door a little.... enough to help hone in on the cause. I get annoyed when their effort at a "fix" is to put grease on the striker or so forth though rather than deal with the underlying issue.
Sounds like I need to get the banging sorted and if the rubbing is still their maybe look at the tubing. I wonder if alignment is the real cause / fix and people haven't had it done so ended up having to g o the tubing route???
