Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 51
Thread: Creaking/squeaking doors and door seals
    Sigh.. yep same design flaw, same fix.
    Glad I kept my irrigation piping.
    Thanks for the much better pics.. recommend this to anyone who suffers the dreaded creaks.
    Nov 2009
    SEQLD
    Thanks for posting! Will give it ago when I'm back from holidays.
    MY20 Golf GTI TCR
    MY20.5 LR Defender P400 HSE
    Nov 2012
    Tried the same irrigation pipe today and didn't work at all. Back to the drawing board
    Dec 2008
    Sydney/Canberra
    Try the method I mentioned, if you've got a set of spline sockets.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Sep 2012
    Townsville
    BAD WOG you must have a slightly different sound to what I was experiencing
    ... Also in that irrigation pipe there is two different types. One is softer than the other
    . You need the harder one
    2014 VW Golf TDI Highline DSG - Limestone Green, DAP, Xenons
    2018 VW Golf R Hatch DSG - White Silver, DAP , Dynaudio
    2016 Skoda Superb 140TDI - Family Members
    2013 VW Amarok TDI420 Highline Auto - Family Members
    Also note that over time the pipe can eventually give a little - you can either replace it or some Mk6 owners spliced a second lot of pipe into the first. I don't know if the Mk7 has the same clearance.
    Creaking doors
    2000km in and I've some vibrations and creaks from panels, mostly from the front passenger side and some from the base of the center console. Eh, what can you do, living in Australia with our temperatures and road conditons they will always appear. The door ding I found when came back to the car park 2 weeks into ownership annoyed me more.
    May 2011
    Albury / Wodonga
    Is it a design flaw or deliberate? Could there be some reason that the, presumably fairly clever, VW engineers have left that hole in the door seal?
    Then again, they did let loose the 118 twin charger, dry clutch DSG, and those diesel injectors on the public didn't they...
    Looking for:- RS4 B7 Avant.
    Current:- Amarok V6 Sportline; Mazda CX-9 Azami AWD
    Previous - Mk 6 R manual; Mk 7 R manual; Passat 130 TDi Wagon. Mk 7.5 Wolfsburg Wagon.
    Quote Originally Posted by Paul_R View Post
    Well lucky for us the door seal is split so we can go out to a garden shop and slide irrigation pipe in there. Those who have experienced the annoying creaks would be buggered if the door seal was joined like on most other cars I've seen/owned. Then again they never creaked either..
    Apr 2014
    Nsw
    I just tried the pipe trick and the wax trick and no luck. I don't know what the issue is but it's driving me nuts. On a forum in Europe I saw they added some black tape to the inside of the window sills and that helped. Noise is on the passenger front door. I wonder if others have the same issue on the passenger door.
