Yep, my new GTI will do it up certain gutters/driveways. Gummi plege helps it for a few weeks then comes back.
Seems to be a common thing with VW's. My mk6 did it bad and my mk5 Jetta that we still own does it too.
Upon my daily drive to get coffee, as I went up the drive way to the coffee shop (at an angle) I heard all the doors creak quite loudly!!
And from there on I could hear it creak on every road surface that was not level.
I spent the remainder of the day in a paranoid state thinking the car was going to fall apart after just 5000km.
Was going to book it into the dealership to demand it be fixed ASAP but I thought I should see if any one else has this problem.
I found out that yes others do have it and it is a simple fix.
Here is the link to another forum
Creaking doors? Mystery solved - GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum
And this is the fix
1z Einszett car care products - Gummi plege stick 150ml
So I have ordered this and will report back when it arrives
In the mean time if any one else has/had or knows of this problem please feel free to let me know
Alex
2014 VW Golf TDI Highline DSG - Limestone Green, DAP, Xenons
2018 VW Golf R Hatch DSG - White Silver, DAP , Dynaudio
2016 Skoda Superb 140TDI - Family Members
2013 VW Amarok TDI420 Highline Auto - Family Members
MY20 Golf GTI TCR
MY20.5 LR Defender P400 HSE
$5 at Bunnings on irrigation pipe fixed the issue on the 6, still got half a roll for the 7 assuming it's the same issue.
If so, make sure it's the hard plastic pipe, not the softer flexible one, and run it through the gap in the door seals around the windows. Worked a treat on the 6, I'm guessing the 7 hasn't fixed the problem. Big thumbs down VW!
Can't believe they didn't fix this problem in the MK7. Dreadful.
Is this the same sort of squeak that appears to come from the driver side B pillar? I find that opening and closing the rear passenger door makes it disappear for a couple of days/weeks, but I could never work out why this would fix it until I read this thread.
Dutch77 could you please put up some pictures of the pipe and where you put it?
Thanks Alex
Also try loosening the latch mechanism and spraying the surface of it where it fastens to the inside of the door with silicone spray, then re-tighten.
I've found this to be the most effective, and longest-lasting solution.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
For those who are interested, the following thread describes the problem - as it manifested in the Mk6 Golf - and its solutions, in detail:
B Pillar clicking / ticking & door rubber / seal creaking / squeaking
Pretty sure there's some better pics in the thread Adam has referenced, but here is a really bad pic of where the tubing goes - I just held my leftovers up as some kind soul unwound the whole roll and threw away the packaging. It's the non-flexible 4mm irrigation tubing which as a bonus I used in the garden as well.
Assuming the 7 is the same as the 6 and current Polo the door seal is in two parts and the pipe slides between the two. The seal should still be tight enough to hold it in place. I'd go all the way along the seal on all doors. On the 6 it ended the creak on all bar the most angled of driveways and I never replaced it or had it fall out.
(I've demoed this on the mrs' Polo which is making way for my new Dub)
Went to bunnings and got the irrigation pipe and installed it in the door seals.
Worked 100% perfectly!! Best $3.95 I have ever spent!
Recommend it to anyone who is having the creaking sound in their cars.
