Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 51
Thread: Creaking/squeaking doors and door seals
  1. #41
    May 2014
    Hi Guy, how did you get the hinges to move? I loosened the two bolts on the car body but the hinges seem welded in place. Even thumping them with a mallet didn't get them to budge. I assumed the paint may be stuck together.
    I guess if VW do the work and the paint around there is messed up adjusting they can touch it up .
    Unfortunately door striker adjustments haven't done the job for me. I can still make the door rattle/bang by lightly pressing on the glass divider or top of the door.
  2. #42
    Sep 2012
    Townsville
    Doors creak when opened/close
    My 1 year old golf has all of a sudden started creaking when I open and close the drivers door.
    It sounds like a door from a 100 year old car :-/
    I'm going to take it into the dealership.
    Has anyone else had this problem?
    How could the hinges be buggered after just one year?!?
    2014 VW Golf TDI Highline DSG - Limestone Green, DAP, Xenons
    2018 VW Golf R Hatch DSG - White Silver, DAP , Dynaudio
    2016 Skoda Superb 140TDI - Family Members
    2013 VW Amarok TDI420 Highline Auto - Family Members
  3. #43
    Cause the hinges and seals on VWs, to me, just seem dodgy.
    Maybe it has something to do with them being designed for European climates but need constant lubing. I have had to do the seals on my Golf every 3000kms so just doing it again.
  5. #45
    Dec 2012
    Melbourne Vic
    Does it only happen to the rear doors when the front doors are closed? Try opening the rear doors when the front doors are open. I think it has to do with the seal between the front and rear door. I have the same issue.
  6. #46
    Dec 2014
    Perth, WA
    I had the same issue on the rear left door, it was just the rubber lining rubbing on the car so I simply pushed it up so that it would no longer rub
    | 2014 Golf VII | DSG | Tungsten Silver |
  7. #47
    Nov 2009
    Read through this thread for info on lubricating seals:
    B Pillar clicking / ticking & door rubber / seal creaking / squeaking
    Hinges - as mentioned above you can use a general purpose grease/lubricant on the hinge as required.
  8. #48
    Sep 2012
    Townsville
    So after a trip to the dealer... It turned out to be the door check strap was faulty. Replaced it and all good .
  9. #49
    May 2011
    Melbourne, Vic
    Hi,
    I've got a rattle in my doors at the handle end of the door (not the hinge end). Any suggestions on what I can do to resolve the issue? It's happening to all four of my doors on my Mark 7 Wagon.
  10. #50
    Mar 2008
    Squeaky door seals
    Hi, anyone else having squeaky/noisy door seals? I have read that a solution is to put some irrigation tubing between the felt on top of the door. My rear doors are very noisy.
    I have read about this issue with the mk6 but haven't heard anything about the mk7.
    Mk7 Golf GTI PP DSG, Tornado Red
