Results 1 to 10 of 13
Thread: Coming Home Lights
    sydney
    Coming Home Lights
    Hi, I have a 90TSI which did not come with the ''Coming Home Lights". Is this a feature that can be retroffitted. Does it require additional parts or is it simply a computer coding change. thanks
    MY 14 Golf MK7 90TSI DSG Night Blue
    May 2013
    Orange NSW
    You would probably be able to recode the option with a ross-tech cable. You might find other little tweaks that maybe nice to have as well.
    08 MY09 R32, DBP, DSG, GIAC, R8V10 reps, KW V3, RNS510/VIM/BT/MDI, region free DVD, switched Haldex, s2t paddles,HPA dogbone rubber,Mk7 climatronics, FIS+, Adams/RDA discs & Hawk pads, Garage button, GruppeM. Front fogs, Milltek. CF Chin spoiler.Strut support. LEDs Alloy front suspension bits.....
    http://photobucket.com/gregsr32
    Nov 2009
    With the Mk6 it was a feature of the "Highline" version of the Central Electronics Control Module (CECM). I'm not sure how the modules are classified or features divvied up between them for the Mk7, or whether the 90TSI gets the Highline module or not. A scan of the modules with VCDS and a quick check of the corresponding part numbers against carsystems.pl should give you an indication.
    (Here's the latest CECM on carsystems.pl - I'm not sure if it's a Mk6 or Mk7 part though: Central Electric Module 1K0937087AE Highline - LED Xenon - High R20 - Soft 0709 - Upgrade -.)
    Quote Originally Posted by AdamD View Post
    Adam: I don't know whether the BCM needs to be changed either but it is a simple matter to test the setting in the adaptation channel in the Cent Elect. Module to find-out. Of more interest (to me, at least) is the question of whether the 90TSI has an "auto" position on the light switch. I had thought that this was a necessary facility to enable CH & LH function (i.e. In addition to flashing the high beam lever).
    Feb 2013
    northern Perth WA
    Are you sure it isn't there? I thought it was missing in mk7 vs mk6 (wasn't happy!), and eventually dug round in the on-screen centre console menus and found it and enabled it. Bit like dimming the dash lighting - a simple knob would have been far easier than computer controls. And here was me nervous about power windows 15 years ago....
    Nov 2009
    Leaving Home requires a light sensor. Coming Home does not, as it is manually triggered.
    sydney
    I can confirm that there is no "auto" position on my light switch. I am more interested in the lights switching on when I unlock the car with the remote control. Anyone with a base model 90TSI added this feature?.
    Quote Originally Posted by bru20vt View Post
    bru20vt: Ok. I think that it might be useful to first establish a common understanding of terms.
    According to my mk7 manual this is how VW defines the function (and I'm paraphrasing a little - but it's written on page 111 of the manual):
    • Comming home lights are switched on when the driver door opens (i.e the driver leaves the car to "Come Home")
    • Leaving Home lights are switched-on when the driver is approaching/entering the car (i.e.the driver "Leaves Home" and enters the car using the fob-key).
    From what you have written, I believe that you want the latter.
    For the leaving home function to operate, two things must happen:
    1. The twilight sensor must record a "dark" sky (as suggested by Adam_D), and
    2. The light switch must be in the "auto" position.
    This means of course that your 90TSI must have
    • a RLS (rain-light-sensor), or a RLHS/RLFS (rain-light-humidity-sensor)- The spec sheet for the 90TSI says that it doesn't have one of these, and
    • the light switch must have an "auto" position - You have confirmed that your car doesn't have such a switch-Alas
    I have enabled CH/LH on my car and I can confirm that the leaving home function will not work if the light switch is in the "0" position.
    But if you have access to a VCDS cable, then you could try the tweak to enable CH/LH function. If it doesn't work (as I suspect that it won't), then simply revert the adaptation channel setting back to its original value. The Stemei.de site has these instructions, which you will find here. Please be aware that you will need to use something like Google translate to view the site (it's in German)
    Good luck with the project and please let us all know how you fare
    Mar 2009
    Southside, South Australia
    Courtesy Lights - Coming Home
    Hi Gents,
    thought I'd run this past the brains trust as I can't seem to find much info on this.
    Courtesy lights
    when I unlock the car the lights come on for 30 seconds, which is what I have set for the 'Leaving Home' option.
    The same is supposed to happen when you return home, but nothing but the interior lights stay on and when the car is locked, they turn off. Is this by design? I'd assume that the headlights should stay on for 30 seconds, but they don't. Am I missing something?
    TIA
    2004 V5 Bora ~ Eibach Pro + Bilstein B8 ~ Tyrol Brake Upgrade
    MY15 Golf Wagon Comfortline
    Mar 2015
    Warner, QLD
    By default, the coming home lights don't come on automatically.
    To turn them on, flash the high beam once after you've turned the car off, and they will stay on for your set duration.
    You can change this behaviour by checking out the VCDS reference thread.
    I suspect VW have done this for two reasons:
    1. You don't get randoms coming up to you telling you that you've left your headlights on... Yes it's happened to me a couple of times
    2. You may have pulled into a driveway facing a window, and having the lights on may disturb to the people inside.
    Golf MK7 103TSI Highline Wagon | Limestone Grey | DAP2
    Golf MK7 110TDI Highline Hatchback | Tungsten Silver | DAP
