Same situation with our 2012 rs octavia. Short trips and still on the original battery !! Low tech cars ftw
I had mine changed under warranty no problem. They just need the car for 2 hours just to confirm it’s the battery.
2015 Golf R. Lapiz Blue.
If you have VW Assist, you’ll most likely get it replaced for free.
Mk 7 R Wagon Wolfsburg. APR Stage 1. Removable towbar.
Resolution.
Diagnosis and replacement under warranty as part of VW assist today.
^^^ I bet that VW assist didn't bother to tell the network module in your car that it now has a new battery and to stop charging/discharging it as if it was a battery of the age of the previous battery. I bet that they simply physically swapped new-for-old and just drove away- without plugging a device into the OBD port near the accelerator pedal?
I would be delighted to be advised otherwise
^^^^yes - it's relatively easy to check: go to the CAN Gateway module @ address hex19, select adaptation-16, search for "MAS06108" and select IDE03256-MAS06108-Battery adaptation-Battery Serial Number. The factory setting for the original battery would have been 1111111111 (i.e. hexFF) - if the setting is still hexFF, then likely the CAN network is oblivious to the fact that the car now has a new battery!
PS - here's how to do it properly (mk7s have UDS modules - so use the section of the video with this protocol):
