Page 22 of 39 FirstFirst ... 12202122232432 ... LastLast
Results 211 to 220 of 389
Thread: Burger Motorsports JB1 Tuning Module + Cable
  1. #211
    Jul 2016
    Hello All,
    New stock have arrived. For those who have previously received a coupon code via PM, you can use the same code to order. Please note that AutoInstruct will allow 48hrs for orders to be placed (I.e. orders should be placed by midnight 1-Oct). Unfortunately, if you miss this deadline, we won't be able to reinstate/honour the group buy price.
    VW MK7 Golf GTI 40 Years | White | DSG | JB1 | Advan Racing RS-DF | Michelin PSS | Current
    PORSCHE 987.2 Boxster | Silver | PDK | Capristo Exhaust | BMC Filter | OZ Racing Alleggerita | Hankook R-S3 | Current
    VW MK6 Golf R | Blue | DSG | GIAC Stage 1 | Sold
    VW MK4 Golf GTI | Red | 5 Spd | MTM Stage 5 | Sold
  2. #212
    Aug 2015
    Great way to start the long weekend Cheers mate! Order placed!!
    Quote Originally Posted by urxtream View Post
    Hello All,
    Jun 2015
    Willoughby
    Hello All,
    just popped my order in too - thanks very much!
    MK7 Golf GTI 40 Years | Carbon | Manual | Current
  4. #214
    Jul 2016
    Just a friendly reminder the Group Buy Coupon will expire by today. If you would like to get your hands on a JB1, hurry
  5. #215
    Aug 2016
    Chippendale, NSW.
    I changed my setting over the weekend to "Map 6" and it is more linear across the board now, with less of a sudden rush of power, like a diesel like delivery and more in line with a petrol like, smoother delivery.
    MK7 Golf GTI 40 Years | Carbon Steel | DSG | Front Windows Tinted | JB1 (Map 6) | Sunroof | Folding Mirrors Retrofitted | Current
    W211 E55 AMG | Previous
  6. #216
    May 2013
    Quote Originally Posted by NSNO View Post
    Ah, that's interesting. I'm still on the default map and I don't like the non-OEM power delivery. It feels like it's lost its smoothness. I need to do some investigating I think after the first service in about a month's time.
    MY08 Mk5 GT Sport - sold
  7. #217
    Sep 2016
    sydney
    Some feedback after fitting the JB1 to my 162tsi Skoda superb....Pretty darn good! Amazing upgrade for the $$$. Thanks again to the OP!
    Install took 30 minutes tops and I lifted the car on one side and used a jack stand for safety. Took off every bolt for the plastic pan but left the very last one on so easy to refit. Have put the unit in the battery box along with the USB cable (tight fit but all ok).
    I am using map1 and car pulls like a freight train. Wheel spin like mad in 1st, 2nd and into 3rd if too heavy with the right foot. I find it best to be progressive with the accelerator and once past the 'wheelspin' range I can be as heavy as I want. Have had many surprised drivers seeing a large station wagon pull away with such speed. Have not really had problems with a turbo rush past the 2000rpm range where the boost comes on as I moderate the accelerator. If I go crazy WOT from standstill then the TC kicks in and lights flash everywhere and it bogs down. at 2krpm to about 6krpm it really really goes hard. The car has been transformed without sacrificing fuel consumption as below 2krpm there is little to no boost. I have experimented with some conservative map6 settings which I will probably run in the height of summer so as not too get heat issues - probably dial down to 4ish + boost. I will be doing some logging and seeing how the car is responding but having too much fun right now. Have also bought a OBDeleven which has some live data for fuel trims so will be handy when I get around to it. I have also mucked around with the OBD to do some VCDS changes but its doing my head in but have managed to get traffic reports enabled.
    All in all this is the best $600 I have spent and even at full price it is worth every cent!
  8. #218
    Jun 2016
    N/A
    Few conclusions and observations so far about the Clubsport + JB1 combo in particular:
    I have experienced some non-linearity on both map 1 and 6 but only for a moment when I suddenly floor it. It's as if the car instantly hits some boost or torque threshold and holds back for a split sec before the revs continue to build up. If I go more progressively on the throttle it does not happen. No lights flash, this is not related with traction.
    The Clubsport's over-boost function complicates things and hinders consistency. Sometimes it comes on sometimes it doesn't (I don't always remember to try and drill a hole with my right foot on the floor to activate it) so you don't always get the same amount of extra power. I've timed 60-160km/h accelerations with racing GPS device (no smartphone GPS) and I've seen some map 6 runs being almost identical to stock runs with the map 6 only winning maybe 0,5" at the upper end, while on others the JB1 shoves 1" off the stock time, all other conditions identical. That clearly shouldn't be the case if the car had gained a permanent 50-60bhp/100Nm across the entire range.
    In a way, with the JB1 you ensure at least that you get the full stock power of 290ps+++ (more like 300-320) every time and if you always remember to bury your foot as hard as possible and are in 3rd gear and above you get close to the 350-360 mark. This is why you either need to code out the over-boost completely or use a piggyback that controls absolute pressure and makes up for the non-overboost situations, which is what the JB4 will hopefully be able to do.
    Also, at least on stock Bridgestones, don't expect to bury your foot and go at anything below 60km/h, the torque overwhelms the tyres easily. Losing a few tenths and going easier up to 3rd gear works better. With that sort of modulation that might sound slow, I was ahead from a stock Golf R from a 20km/h 1st gear roll with the gap increasing (in my favor), and that was on map 6 and without over-boost activated (didn't even hit the kick-down switch). Considering that was 1st gear and I had to beware of the wheel-spin I was quite impressed. From the way it looked, if we rolled from 2nd 50/60km/h it wouldn't even come close.
    All in all, I'm happy to have it on the car. Certainly gets the car to the next level of performance that coupled with the car's handling/cornering ability makes it impossible I think for almost any non-hyper exotic to escape from it on road or track. But, there are some complications to fully exploit it, that should be sorted with the coming JB4 upgrade and a set of better tyres.
  9. #219
    Sep 2016
    Nice detailed description Ringo. I wondered how the over boost function might work with the JB1.
    Was the Golf R stock or did it have a JB1 fitted too? The extra weight of the R would hold it back compared with the trim 40th, especially if it was stock.
  10. #220
    Sep 2016
    JB1 with cable just ordered - cheers for organising urxtream!
