Page 4 of 39 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 389
Thread: Burger Motorsports JB1 Tuning Module + Cable
  1. #31
    Sep 2016
    sydney
    Hi Guys
    Sorry if this has already been answered somewhere but am wanting to know if anyone has had problems with traction with this unit stock standard map1?
    I have a brand spanking new skoda superb 2016 162kw version 6spd DSG (same engine and setup as as octavia RS). Any other issues?
    Also how much extra power and torque from the standard map1. Can't seem to find it. cheers
  2. #32
    Apr 2010
    VW Matrix
    Quote Originally Posted by boy123 View Post
    Hi Guys
    Coming from someone with a modded RS, you're likely to have traction issues in the wet even on a stock file - naturally, this will get worse as you add more power. Traction will ultimately come down to how you apply that power/feather the throttle. Adding things like coilovers/springs, torque arm insert, stiffer bushes etc will help minimise wheelspin/hop but at the end of the day it's a front wheel drive vehicle.
    Had the 206TSI AWD Superb been available in Jan 15, I would have jumped all over it - proper sleeper in my opinion!
    Further info on JB1 VW Group - N54Tech.com - Your Source for International Turbo BMW Racing Discussion
    GOLF R Stage 2+
    MK3 OCTAVIA vRS WAGON
  3. #33
    Jun 2016
    Melbourne, Victoria
    Quote Originally Posted by NSNO View Post
    So is it permanently connected once you connect all the plugs or do you upload the map and then remove it?
    Stays permanently connected.
  4. #34
    Jul 2012
    How easy is it to install once you receive the unit?
    There are 3 plugs that need to be connected. If you have a Golf R you need to access the third from underneath the car. If you have a GTI (not sure about the clubsport) you can apparently reach all the plugs from the top. I'll hopefully know what the truth is sometime next week
    It needs to be connected to work. If you take it off, your car goes back to totally stock. The JB1 is an piggyback style unit. This means that it intercepts the signals running between the engine and ECU and modifies them as required before sending them on their way. The ECU thinks it's talking directly to the engine, and the engine thinks it's being instructed by the ECU only.
    The really attractive part of all this is that you can remove it and its very difficult to tell the car was ever tuned. Nothing is changed on the ECU, so no "naughty flags" are set for the dealer to screw you over with. The plan is to take mine off for each service.
    2016 GTI Performance | Pure White | JB1 | Dog Bone | Full Tint | Stop/Start Delete | Avatar by sandwg
  5. #35
    May 2013
    Quote Originally Posted by mattaus View Post
    Yep, that's what attracts me to this and I plan to do the same and remove it for each service.
    MY08 Mk5 GT Sport - sold
  6. #36
    Sep 2016
    sydney
    Quote Originally Posted by masev View Post
    Ok thanks so much for your reply. The RS goes well with the box? I suppose if I am careful with not so aggressive takeoff then I can enjoy the extra power oomph in the mid rev range. Interested to hear what map you using? I am thinking to configure the boost profile by reducing the rpms to limit the wheel slip (use the 500rpm increments). Does that make sense? You might see an old man driving a superb slowly at the lights and then all of a sudden take off! ha
  7. #37
    Sep 2016
    sydney
    I want to add to the group buy JB1 + cable but alas don't know how to add it to the first post list? Sorry a newbie to all this stuff (old fella!)
  8. #38
    Jul 2012
    urxtream will add you when they see your post, don't worry
  9. #39
    May 2014
    Richmond, NSW
    I'm in for jb1 + cable.
    Sent from my GT-I9506 using Tapatalk
  10. #40
    Jul 2016
    Boy123 and Dudgemo,
    Can you please advise the Year, Generation, Make and Model of your cars please?
