Page 37 of 39 FirstFirst ... 273536373839 LastLast
Results 361 to 370 of 389
Thread: Burger Motorsports JB1 Tuning Module + Cable
  1. #361
    Jun 2016
    Wireless unit turned up just now, installed.
    Mirrorlink with VIM.
    Must have I feel.
    Anyone found a work around for Iphone with mirror link, ferret has wireless but has Iphone
    Skoda RS 230
    "The Grey Ghost"
    SG-TP-AB RS230 - Timeline
  2. #362
    Jun 2016
    Has any one used a water sprayer for there Rad/intercooler before?
    Only for track days (30mins)
    Looking in to a kit
    DEI 080140 Cryo2 High Performance Intercooler Cooling Water Sprayer Mist System | eBay
    But its only 1.1L
    So....
    HYDRABIT 100L ATV WEED SPRAYER CHEMICAL GARDEN FARM WATER SPRAY PUMP DRIVEN TANK | eBay
    Might be more up to the job....
    Skoda RS 230
    "The Grey Ghost"
  3. #363
    Jun 2016
    DYNO results
    Runs had Racing Line Air Filter
    Stock RS230 is 169Kw/230hp at the Flywheel.
    Below is at the wheels
    Pink - Stock 153.5 Kw / 205.8 hp
    Green - JB4 Map 1 (4.5 psi extra) 170.1 Kw / 228.1 hp
    Red - JB4 Map 2 (5.0 psi extra) 176.7 Kw / 236.9 hp
    Burger Motorsports JB1 Tuning Module + Cable-dyno-photo-jpg
    Skoda RS 230
    "The Grey Ghost"
  4. #364
    Jun 2016
    Sydney, 2224
    JB1 Revision 1?
    Hi, Can any tell me if the JB1 revision 1 modules are the same for the R and GTI models?
    Ive been told the JB1 revision 2 and JB4 are the same but just wanted to confirm the JB1 revision 1 modules are interchangeable between the two cars also.
    Thanks, Stellio
  5. #365
    Jul 2009
    QLD
    Quote Originally Posted by stellio78 View Post
    Thanks, Stellio
    Checkout BMS, it goes on HP
    VW JB1 Tuner, Mods, Upgrades, Accessories & Parts - BurgerTuning.com
    2017 MY18 Golf R Wolfsburg | Oryx White | DSG / 2021 MY21 T-Cross Style | S+V Package | Limestone Grey
  6. #366
    Jun 2016
    Sydney, 2224
    Well if you look at it that way, that contradicts what I've been told.
  7. #367
    May 2016
    Matraville, NSW
    It should be different, as the signal that it intercepts and changes would be different. Different turbos etc.
    Perhaps the confusion between the JB1 rev 2 in terms of hardware to JB4 is that the rev 2 is jb4 ready.
  8. #368
    Oct 2010
    Quote Originally Posted by HPRS230 View Post
    DYNO results
    Good to see a comparison of stock vs tuned at a few psi levels.
    As for misting the intercooler, I built my own around 10 years ago for an R32 skyline and it worked ok, but I never had any way of measuring how effective it was.
    Another option is to blend some E85 to help reduce temps, and start playing around with JB4 Map6. Golfmk7.com has a thread on JB4 tuning in the GTI section.
    Fixxxer
    Lapiz Blue DSG Golf 7R
  9. #369
    Jun 2016
    Can we use e85? Or a low % mix
    Skoda RS 230
    "The Grey Ghost"
  10. #370
    Oct 2010
    Low % mix. If you live on the southside of Brisbane, you can find E85 easy.
    Try a small blend between 10-15% E85 and see how you like it. I assume you have the same (slightly smaller) tank than Golf R.
    Add 6-7L of E85 and top off with 98 RON petrol.
    Caltex sells E85 (btw 70-85% ethanol + >15% regular ULP) at some servos, around $1.10/L. United sells proper E85 (race blend, 85% ethanol + 15% 98 RON) around $1.40/L .
    Enjoy.
    Fixxxer
