Page 21 of 39 FirstFirst ... 11192021222331 ... LastLast
Results 201 to 210 of 389
Thread: Burger Motorsports JB1 Tuning Module + Cable
  1. #201
    Jul 2016
    Thank you to everyone that placed an order and also to AutoInstruct for offering the special Group Buy discount to us. The Group Buy has officially ended yesterday 26/9/2016. So if you'd like to order a JB1 now, you would have to order it directly on AutoInstruct's website at the recommended retail price. For those that ordered on or before 26/9/2016, I'll PM the coupon codes to you once the next batch of stock arrives.
    VW MK7 Golf GTI 40 Years | White | DSG | JB1 | Advan Racing RS-DF | Michelin PSS | Current
    PORSCHE 987.2 Boxster | Silver | PDK | Capristo Exhaust | BMC Filter | OZ Racing Alleggerita | Hankook R-S3 | Current
    VW MK6 Golf R | Blue | DSG | GIAC Stage 1 | Sold
    VW MK4 Golf GTI | Red | 5 Spd | MTM Stage 5 | Sold
  2. #202
    Sep 2016
    Received mine yesterday. I'll be installing it Friday - public holiday in Australia so more time to play!
    Thanks again for organising this urxtream.
  3. #203
    Jul 2016
    Quote Originally Posted by NSNO View Post
    How do you add a signature, I want to add my car details.
    Click Settings (top right corner) => click Edit Signature (left hand column somewhere in the middle)
  4. #204
    Aug 2016
    Chippendale, NSW.
    Quote Originally Posted by urxtream View Post
    Ok thanks, done.
    MK7 Golf GTI 40 Years | Carbon Steel | DSG | Front Windows Tinted | JB1 (Map 6) | Sunroof | Folding Mirrors Retrofitted | Current
    W211 E55 AMG | Previous
  5. #205
    Aug 2016
    Chippendale, NSW.
    Has anyone adjusted their setting on their JB1 yet and if so what have you changed it to and have you noticed much difference from the stock tune that it comes with? Also I downloaded the software today but I'm not sure if it is the latest version. How hard is it to remove the case from the JB1, so that I can fit the cable to it. Does the car need to be in sleep mode to upgrade the setting?
  6. #206
    May 2016
    Matraville, NSW
    Case removal easy small flat head screwdriver in and twist.
    Personally I would let it go into sleep to attach the cable, but needs power to change maps.
  7. #207
    Jun 2016
    N/A
    I'm pretty sure it states that ignition should be on when connecting to the unit via the usb cable. As above, flat screwdriver and twist, super easy.
    Switched mine to map 6 which runs lower low end boost and it seems to lack a little of that initial push back. However for an extra piece of mind and since I don't usually need all that low end torque I might keep it there.
    One more thing, launch control with JB1 in this car is pointless unless probably if you run semi-slicks which have got up to temp. Tried it yesterday, and that was on the lower map 6, immediate smoke and stink of burned rubber while desperately trying to keep the wheel on a straight line. I know Potenzas have never really been up to the job but that was almost scary.
    Not that I really bother with launches but I tend to try all my cars once or twice in that. Also, maybe the 3K rpm that the LC rises up to is too much, 1.5K seems a better option but I doubt I'll try it again until I switch tyres.
  8. #208
    Sep 2016
    Quote Originally Posted by ringo View Post
    Impressive result all the same!!
  9. #209
    Aug 2016
    Chippendale, NSW.
    Yes I got exactly the same result but on the stock "Map 1", the tyres just wheel spun like crazy followed by the smell of burning rubber. I just don't think that FWD cars are made for fast launches.
  10. #210
    Jun 2016
    N/A
    They obviously aren't. Especially with all the extra torque from the JB1 I almost felt like I was kicking my dog, it was brutal. And let's be honest the only point to do it would be bragging at the pub that you managed a x,xx 0-60. In all my driving years I have pulled against many cars on the road or they have pulled against me if you want, (always on private airfields) and that was always from a roll, where I didn't have any problem putting the power down. You don't usually get to roll down your window and ask the other guy to line-up with you, and then launch at the count of 3, do you? Unless of-course you are going to the drag-strip or join underground drag races or whatever.
