^^^ bor123. Hi.
interesting how repetitive the fault is on your video. I assume that you like your music loud and that the fault was being modulated by the sub-woofer sound - maybe?
According to the mk7 wiring diagram - both the rear lid contact switches and the twin coils in the sub-woofer speakers terminate on what VW call THK which is described as Coupling point on rear lid. This is a 10 x pin connecting block.
There appear to be 2 x contact switches on the Rear lid locking unit - so I suggest that you check the connections on pins #2 and pin #7 (this 2nd switch is used for the anti-theft alarm) on THK. Hopefully the pin numbers are embossed on the coupling housing.
