No, nothing as clandestine as big-brother intervening - I deleted my post because of a fat-finger syndrome (mine). I didn't have the mental fortitude to re-write it, so good that you kept a copy!!
Yes, J1067 is located in the left-side rear quarter panel. The "TTxxx" coupling points are on the inside of the left/right (see reference to "L" & "R" on the diagram) door skins. - so these are probably the most convenient splicing points for the new LEDs
hmm...... I've not read the post in the "rival forum" - but how do you "measure the resistance of the o.e. led"? By definition, an LED is a semiconductor device so it has a non-linear relationship between voltage and current. I guess that you could generate a graph like this:
And use ratio of dv/dI (i.e. the mathematical first derivative of the slope of the curve) - but it would be lots of work and I'm not sure that the answer would be accurate. So I can't comment on the suggestion from the other forum (but it seems mighty odd - to me at least!!).
The single-transistor driver in my deleted post might look scary to anyone who is not familiar with these circuits - but it really is the stuff of electronics 101.
The problem that the auto electrician will have for this project is that he/she knows nothing about the internal circuits inside the module that are connected to the 2 x pins that drive the OEM LEDs. So he/she doesn't know the designed wattage of the driver circuits, or if these pins are auto-protected against overload.
The additional load of the new LEDs should not be high, but it really depends on the chosen LEDs (especially if you want high intensity LEDs)
One option is to just add the new LEDs in parallel with the OEM LEDs and hope for the best. This seems like a "courageous" and very blunt approach - to me.
A far better way (IMO, of course) is to provide a degree of electrical isolation between the driver circuits inside J1067 and the load from the new LEDs. My transistor suggestion does this.
But there are countless other ways of achieving the objective of electrical isolation - so I have no doubt that a competent auto electrician will have other suggestions
PS: I'm not sure how your car is fitted-out, but some MQB platform vehicles have the following adaptation channel in the hexA5 module:
