Blind Spot Assist setting failure to stick
My Blind Spot Assist setting was failing to stick. As soon as R(everse) was selected it went to Off.
Back from the Service Department yesterday the problem of the Blind Spot Assist setting failure to stick seems to be fixed.
fyi they delved into on board diagnosis and found "numerous error codes" which they suspected were caused by my efforts at adding non-genuine devices messing with the electrics (*see below). They were pleasingly diplomatic about it as they could not be sure and there was no charge under warranty.
I learned that there are two types of error codes which as I understand it are ones that are merely logged occurences (big brother type) and the other type make a change which is retained and require deletion.
To my mind, what I did should not have caused a problem but it certainly sounds like the fault is with me. VW advised not to connect any non-genuine devices to the OB2 port. If anyone can advise what I should do in future, please advise.
* In chronological order, here are the non-genuine devices added
1)dash cam This simply required plugging into the 12V socket on the centre console.
2) heads up display. This one of those that lie on the dash and reflect on the windscreen. It plugs into the OB2 socket and a small USB type plug goes into the device. I liked it because it showed the true speed which differs from the o.e. instruments. I disconnected it because a speeding alarm (additional to the o.e.) was annoying.
3)another dash cam. This one is a rear-view mirror type that is placed over the o.e. mirror. I like it because it is wider than the o.e. mirror and can show the camera image in the mirror itself when a button is pushed. It also comes with a "free" rear camera which shows its image in the mirror, thus no need for an extra screen cluttering up.
4)Instead of powering the free cam from the reversing light I installed it as a front cam which meant I had to power it from another 12V point and have a switch to turn it on/off. Turning it on activates its image in the mirror. I disconnected the car battery and removed it to get access to a grommet for the wiring to go through the firewall. On re-connecting the battery I got a scare as an heap of errors messages appeared but, as is normal, they self corrected when the car was driven for a distance.
5) I installed a 12V multiadapter (4 sockets) from E-bay. It has switches for each socket. It takes 12V from the o.e. console socket and is installed neatly in the 4motion cubby. Thus it has three plugs in it for the first dash cam, the mirror dash cam, and the front camera. I extracted the cubby, and cut a hole in the back to feed the plugs through. I had to disconnect the o.e. plugs at the back of the cubby which power the USB and AUX-IN sockets. They were re-connected.
cars (chronological) Morris850, Morris Mini DeLuxe, Cooper S, Mazda 1500SS, hard times so some old Holden, old Falcon Ute, better times so second hand Lotus Elan +2 (6 weeks, hopelessly unreliable) Chrysler Valiant Charger 770, second hand Datsun 260Z + 2 auto, Mitsubishi Cordia Turbo, Nissan 200SX turbo auto for 20 years(wonderful car burning ZERO oil after 200,000km & no problems when sold.. should have kept it), Toyota GTS 86 auto, now Golf R Mk 7.5 DSG built Aug2018, white.
