Results 1 to 2 of 2
Thread: Fixing what i messed up with obd11
    Feb 2019
    Broadway Worcestershire
    Hi
    Is there an As built file that i can use to restore what i changed with my obd11
    Im getting multiple errors coming up
    Iam lucky to not have bricked my car
    p.s its a december 2018 golf 1.5 tsi 150 r line
    James
    James: Alas - the only way to "bulk-load" the original factory database for your car is by using the dealer's ODIS device.
    But it ain't all bad news because OBD11 has a history function that records ALL changes that you have made. If you access this function, you get the option to email yourself the entire file (see the instructions below). You can then look-through/print the records to identify any "aberrant" changes
