Originally Posted by
gregozedobe
I cannot access any SOC info from the MFD on my 2017 R either, so it's likely that VW have not enabled that particular function. I'm a bit disappointed at the lack of functionality VW have designed into the active instrument display. The data you can show at any one time is quite limited. Some people have suggested that this was deliberate, to differentiate between VW's and the more upmarket (and more expensive) Audi's.
greg: If your car has Start Stop (as it almost certainly will have if it was sold in Australia) then it will have a Battery monitor control module integrated into the negative battery lead - which means that the vehicle is capable of measuring SOC.
This notwithstanding, I suspect that the SOC function has deliberately not been included into the your car (as you say). However, my hunch is that this is for a very different reason than you suggest - I have an Audi A3 8V which shares the same MQB build platform as your mk7 Golf and it doesn't have SOC.
My hunch (guess really) was that WV/Audi deleted SOC from their later model cars because of inquires/complaints from drivers of early model MQB vehicles. Vehicles that contain the battery monitor control module (which enables SOC measurement) also have braking regeneration.
For regeneration to work, a quantity of the battery's capacity must be "reserved" away from normal use to allow for the extra stored energy. Cars with braking regeneration AND SOC invariably registered SOC readings around 70-80%(depending on the quantity of regen energy actually created).
My suspicion is that this resulted in lots of complaints from drivers of early model mk7's - better for VAG to avoid constant explanations by removing the SOC facility in newer models - IMO, or course!
