Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 59
Thread: Battery dying?
  1. #31
    Apr 2011
    Eaglerhawk: I guess NRMA haven't caught-up with advances in newer generation control modules - particularly in cars with Start Stop!
    Most important question is - does the new battery have a BEM sticker?
    No BEM sticker (at least at the top of the battery with the rest of the stickers). But thank you for your steps and wealth of knowledge. I will investigate and purchase something in the near future. I didn't realise that were "new kids on the block", time to research...
    Thanks again. Add another thankful forum member.
  2. #32
    Jan 2014
    Narangba, QLD
    So nobody can shed any light on the slow / long cranking time before the engine fires on my wife's 2014 2.0 TDI?
    MY18 Passat Alltrack Wolfsberg (white) darkest legal tint (SOLD), 2014 Golf 110 TDI Highline (sold after DM Flywheel issues), now 2021 RAV4 Cruiser Hybrid, 2020 C-HR Koba Hybrid
  3. #33
    Jan 2012
    The only long crank issue I had was when I got the timing chain replaced and they put it back together with the timing on the crank shaft out. The cams and crank shaft would do a full cycle before firing up, but this gave me an engine light.
    2015 Golf R. Lapiz Blue.
  4. #34
    Apr 2011
    So, I bit the bullet and got myself the OBDeleven. Did some simple coding yesterday to make sure I knew what I was doing (instrument staging, traffic, sat nav nag...)
    So, tonight I did the battery. As DV52 suggested, the serial number was still the default, the capacity was set to 68 and the battery technology was set to "Fleece". WTF?
    I've set the capacity to 70Ah (written on new battery), changed the serial number, and changed the battery technology to EFB. Have I done the right thing?
  5. #35
    Quote Originally Posted by Eaglehawk View Post
    Eaglehawk: New OBD11 dongle -what are your observations? I like certain features, don't like others. It's simple to use, but it's very slow - even with a good internet connection.
    As for the changes, if the new settings more accurately reflect the characteristics of the new battery, then the changes have to be better! You certainly haven't done the wrong thing IMO!
    PS: the "Fleece" setting" simply refers to the weave of the glass mat in an AGM battery - I think
  6. #36
    Apr 2011
    Ah, I'll change it back to Fleece then. There was a Binary-AGM setting as well.
    The dongle: Yes, I loved the features, but it still does feel "overwhelming" to a new user (I'd hate to think what VCDS would be like). The best feature I think was the "Apps" functions to show you the common settings that are available for your model car. The bluetooth seems to disconnect "at some point" when you first start using it. Not sure if it's a dongle issue or the car dropping voltage temporarily.
  7. #37
    Jan 2014
    Narangba, QLD
    OK so finally today the battery failed to crank the wife's Golf over and it was replaced under warranty. This was by VW roadside assist, not RACQ. I was texting her saying make sure he tells the car about the new battery, but he had told her that the car would work that out all by itself. There were 4 errors which gradually cleared over her drive to work. Thoughts?
  8. #38
    Quote Originally Posted by Jondalar View Post
    Jondalar: hi. I'm just a rank amateur compared to the experienced folk at VW road-assist, but I do like to make sure that any statement from any VW-Australia agent is at least logical (because sadly, many aren't)! So, here's my problem - notwithstanding that a mk7 is a fairly intelligent vehicle, how does it automatically know that the battery is changed?
    Yes, the control modules can see that the voltage has been re-established (after disappearing for a few minutes), but how does the car distinguish between other events that cause this symptom (i.e. battery voltage collapse from a weak battery and battery lead remove and re-connection) and the less frequent act of an actual battery replacement? AGM batteries are also fairly smart devices, but they don't talk to control modules in a way that discloses their identity - they are just batteries!
    I'd like to give the road-assist person the benefit of the doubt and suggest that he/she was probably referring to the error reports that were generated in the removal/replacement exercise and that have subsequently cleared. But it's folly to believe that the car has a similar IQ to that of the road-assist guy and could therefore know that the battery was replaced - without any changes to the CAN Gateway module settings (IMO). If this were the case then there would be no need for Ross-Tech to create their video on battery replacement and there would no need for VW to make the three adaptation channel settings available for consumer use (IMO)
  9. #39
    Hmmm, I replaced the battery in my Mk6 R myself......OEM battery replaced with another Varta battery. I haven't changed anything in the computer though.....
  10. #40
    Quote Originally Posted by willsy01 View Post
    Will: hello and thank you for the comment - though I'm not sure quite how to respond! So I'll just say (politely and with due respect- I hope) that whilst the mk6 and mk7 share a common name for marketing purposes, there is a world of difference in the DNA of their respective control modules.
    One of the numerous changes that was made to the car when the Golf was transformed to the MQB platform was a rearrangement of nearly all of the CAN buses and the introduction of entirely new (to the Golf series) facilities (like Leuchte programming). The inclusion of the battery monitor control module (J367) on the LIN data bus to the CAN Gateway (J533) and the inclusion of the 3 x battery adaptation channels that I identified earlier (which I understand were already present on some Audi models) was part of these changes.
    But as I have said previously, the car won't blow-up if the channel settings aren't altered - what will simply happen is that the car's "internal" understanding of the battery capabilities will rely on the information that has been built-up over the life of the old obsolete battery. In time and if the control modules aren't required to make critical decisions based on the calculated "System Voltage" in the interim, I guess that the obsolete historic values will be eventually written-over by the battery's true data. But it's not an ideal situation IMO if you have paid good money for a new battery. Nevertheless, I fully acknowledge that ignoring this procedure will be an acceptable alternative to some. As the cliche says "it's a free world" - I really don't mind if others are prepared to adopt the Laissez-faire approach!
