Less obviously, what your thumb does with the auto-hold switch also governs the behaviour of the engine’s stop-start function.
If auto hold is switched off, the stop-start system will sit watching the foot brake. As long as you hold the car motionless, the engine will shut down and sit dormant (once warmed through) but will quickly spin into life the moment you lift your foot. That means the engine is alive and ready to react by the time your toe reaches the throttle pedal.
If auto hold is active, by contrast, the stopped engine will carry on slumbering even after you step off the brake, only stirring when you prod the accelerator to set off again.
The small problem that creates is that the engine can’t simply start instantly. In the brief half of a second it takes to whir into action, you can’t help but keep pressing the accelerator towards the carpet. By the time the engine is ready to go, the throttle will tend to be a little too wide open, making it embarrassingly easy to lurch awkwardly away as if you haven’t quite learned to drive.
As a result, I wound up tapping the throttle for an instant to wake the engine before setting off. It’s a predictable means to get away smoothly, but it’s not exactly ideal.
