Alek: Bummer!!!
Alas, I don't understand any of your words in your response above that starts "Ok, so I am isolating errors specific to LED errors. These two replace this from long coding to channel coding..........."
I reaching the end of my suggestions - I ask once more:
Maybe post-up a BCM admap (as a URL link - don't dump the data directly in your post) so we can see how this puppy is programmed!!
If you aren't familiar with the process of creating a BCM admap with VCDS, see my instructions below:
From the VCDS opening screen below, select Applications
From Applications screen, select Controller Channel Map
In the Maps dialogue box, set-up the variables EXACTLY as shown below (take care with this step - check the boxes correctly):
Press the Go button and wait for the magic to finish!
Once the process is complete, look in the sub directory C:\Ross-Tech\VCDS\Logs on your laptop and you should find a new file starting with the name admap-09-5Q0-937-084-AC.......CSV.
Now, because this forum won't accept a .CSV file, you will need to post-up the admap to a third-party hosting site (like dropbox, or any of the lots of other sites). Then include a URL-link to the file in a new post here
