Results 1 to 3 of 3
Thread: assistance / guidance needed
    Sep 2019
    canberra
    Mea Culpa- it was me
    i was putting Stedi Low and High beam LEDs into my daughters Golf 7.5 tsi, and stupidly, i turned on the ignition to test the lights when i had the light housings off the car, which also required the grille to be off. Didnt think the sensor behind the vw badge would **** its calibration. Hence now have a yellow warning light unable to reset with VCDS.
    Question/guidance asked: can it be done with VCDS? or do i have to go to a dealer to do so?
    thanks..
    @meeso - don't be too hard on yourself (it happens to ALL of us)!!
    It's difficult to answer your question without knowing more about the problem. Please post-up a VCDS auto-scan so we can see the error and how the car is equipped
    You can run radar static calibration via basic settings in VCDS.
    Need to enter the Security Access code first, and car has to be 1.5m away from a wall or similar solid object.
