Look at whatever error codes have been recorded, that might point you in the right direction to fix it.
Sounds like your car considers it to be a very serious problem if it is telling you to 'Apply Brake' and then immediately cuts the engine.
Just after starting the car this morning and cruising down my street a message came up in the cluster 'Apply Brake'. I did this and the car shut off. I had to put the car in P, turn off the car and turn on again. Fired up straight away and error gone, thankfully not a busy road and no other cars about.
The battery is 1 year old, AGM and shows good voltage so unlikely to be that. I don't take the car to the Dealer for servicing so any software updates have not been applied for 4 years or so. Not even sure if that may help.
Any ideas? Is an ECU firmware update possibly required? Is this available from somewhere to do myself.
I have checked the forum for similar issue and cannot find any reference.
Thanks
I did a scan with my ODB2 and Car Scanner app, at the time it happened it shows error code 10812 - Functional Restriction due to Pressure Drop.
Any ideas what this might be?
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
Thanks man I did see that. I cleared the error and will see if it happens again I guess.
Hopefully not such a serious one and won’t come back.
