Results 1 to 5 of 5
Thread: Apply Brake message - Car shut off
    Sep 2016
    Just after starting the car this morning and cruising down my street a message came up in the cluster 'Apply Brake'. I did this and the car shut off. I had to put the car in P, turn off the car and turn on again. Fired up straight away and error gone, thankfully not a busy road and no other cars about.
    The battery is 1 year old, AGM and shows good voltage so unlikely to be that. I don't take the car to the Dealer for servicing so any software updates have not been applied for 4 years or so. Not even sure if that may help.
    Any ideas? Is an ECU firmware update possibly required? Is this available from somewhere to do myself.
    I have checked the forum for similar issue and cannot find any reference.
    Thanks
    Canberra
    Look at whatever error codes have been recorded, that might point you in the right direction to fix it.
    Sounds like your car considers it to be a very serious problem if it is telling you to 'Apply Brake' and then immediately cuts the engine.
    Sep 2016
    I did a scan with my ODB2 and Car Scanner app, at the time it happened it shows error code 10812 - Functional Restriction due to Pressure Drop.
    Any ideas what this might be?
    Jul 2007
    Brissy
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Sep 2016
    Thanks man I did see that. I cleared the error and will see if it happens again I guess.
    Hopefully not such a serious one and won’t come back.
