Originally Posted by
nsk_john
Hi guys,
I just bought a VCDS cable and scanned the car. To my surprise, a few fault codes are presented in the auto-scan report.
All but one comes back again and again after clearing DTC.
The report looks like this:
Code:
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 3Q0 035 846 HW: 3Q0 035 846
Component: MU-S-N-ER 820 0611
Serial number:
Coding:
Shop #:
ASAM Dataset: EV_MUStd4CDELP 001001
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 6EFD3AD0B171734EBF-803A
Media Player Position 1:
Subsystem 1 - Part No SW: 3G0 919 605 D HW: 3G0 919 605 D
Component: ABT_Std-2_Nav H43 4060
Serial number:
Engine Control Module 2:
Subsystem 2 - Part No SW: 3G0 919 866 K HW: -----------
Component: MRM2 2015/16 --- 0420
Serial number: --------------------
2 Faults Found:
1559 - Cooling Fan for Housing
B126B 01 [008] - Electrical Failure
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 18
Reset counter: 48
Mileage: 8 km
Date: 2015.09.24
Time: 00:03:39
Anyone knows what this is?
Appreciate any input.
cheers
John: hello . I've not seen the fault code before, but it reads fairly clearly as follows:
- It's most probably related to the fan that cools the electronics in the infotainment unit enclosure that lives inside the glove box
- The fault first occurred when the car had travelled just 8 kms. So it happened when the car was new (probably first leaving the factory)
- You can't clear the DTC because it has occurred on 18 separate times since the fault was first stored.
- The reset counter means that the car has to experience 48 problem free cycles before the DTC clears itself
- The priority rating of 6 means that it's not a crucial fault - VW's rating 6 means that the fault has a long term influence on drivability.
Clearly it's something that needs to be looked-at by your friendly (but sadly, incompetent) dealer service manager because if left unattended, the increased temperature inside the infotainment unit will degrade the electronic components and eventually they will fail!
When you take back the car to your friendly (but sadly, incompetent) dealer service manager, you might want to ask what manner of pre-delivery inspection was carried out.
I suspect that your friendly (but sadly, incompetent) dealer service manager defines a pre-delivery inspection as a car wash and a smile as you hand over the bank cheque!!
