Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Anyone else in the 100000km club?
    Jun 2018
    Quote Originally Posted by jamez View Post
    Hi All,
    Just a quick update, the car is now back on the road.
    I swapped out the ECU as per Gutoneto's advice above, and had it recoded - thanks to Volks Mechanical.
    One wire in the ECU harness needed to be moved - the control line to the radiator fan: in the large ECU connector T94 - move pin 11 to pin 70 (yellow purple wire)
    I found videos detailing how to de-pin and re-pin VAG ECU connectors:
    VW/Audi ECU pin removal - YouTube and vw pin tool (terminal release tool) making your own for free and repairing broken harness plugs - YouTube
    If the links don't work, search for 'VW/Audi ECU pin removal' and 'vw pin tool (terminal release tool) making your own for free and repairing broken harness plugs'
    All I had to do was remove the back cover, remove the locking plates, and then I used piano wire to release the pin and the plastic blanking pin.
    For those playing along at home, the engine fired up fine, but I noticed a fault code: 18065 - Coolant Pump 2 P261C 00 [039] - Short to GND.
    Did some further investigation, and worked out that can indicate the +12V supply to the sensor/item in question is missing.
    Sure enough the fuse SB7 that supplies the charge air cooling pump (intercooler) was blown.
    Most likely popped when I was mucking around with the donor high pressure fuel pump on the original harness and ECU.
    I hope by posting this info, I can give back to the community that has provided me with useful advice, and help someone else sort out their engine swap.
    James
    Hi James,
    That's great news! and even greater that you found out about the wire, I wasn't sure about it as wasn't present to this last bit when got someone to code de ECU (if the wire swap was necessary or just coding).
    T​o come many more KMs to those little engines!
    Guto.
    Golf Wagon MK7 (90 92TSI) - Mods: DQ250 swap (Stage 2), 110TSI turbo upgrade (Stage 2), Bilstein B12, 19" Pretoria, GTI PP sway bar upgrades (front/rear), full GTI tartan interior, GTI color cluster, R Bi-Xenon headlights with AFS retrofit, GTI brake upgrade.
    More to come...
    Jan 2013
    melbourne
    Hi guys I’m currently doing a similar swap but I’m trying to go from a cxs to a czd engine I left the newer engine harness on and just plugged the old ecu in and had the same result with the only code as hpfp I also plugged the ecu that came with the newer engine in and it obviously would not start due to immo I hope I have not damaged it , but I also noticed when it was plugged in the fans ran all the time I’m assuming because of the pinout change I’m hoping anyway
    Jun 2018
    Quote Originally Posted by crzbug View Post
    The first thing you'll need to find out what ECu do you have, old MED17.5.21 won't work with the CZCA/CZDA engines, you will need the MED17.5.25.
    As mentioned by jamez a couple post before it needs to swap a wire to get fans operating normally: "One wire in the ECU harness needed to be moved - the control line to the radiator fan: in the large ECU connector T94 - move pin 11 to pin 70 (yellow purple wire)"
    More to come...
    Aug 2023
    Quote Originally Posted by Gutoneto View Post
    First thing sort out that fan by moving the pin - get yourself a wiring diagram to suit your vehicle and follow my links, no soldering required. The ECU pins are marked on the plastic housing - use a torch and magnifying glass or a phone with a macro lens to see what you are doing.
    Just to add to what Gutoneto says above, if you have the donor ECU from the newer engine, as you found it will throw an immo error and refuse to start. I have read that some ECUs can clear the ABS coding in the event of immo activation, but mine did not - a VCDS backup is a good idea just in case. You will need to sort out recoding the donor ECU to your vehicle, I used Volks Mechanical (do a search), but there may be someone closer to you.
    Another side note, some of the newer engines have variable intake cam angle solenoids and cylinder deactivation solenoids, but I assume the engine would perform similar to the CXS series if they are not connected. Probably the donor ECU with the new engine harness would allow them to be used.
    Jun 2018
    I'm posting here the partial PM that I sent him as public information for future reference...
    "You'll need to run the new ECU unfortunately, he will need to do a full bench reading of the old ECU (virtual reading won't work) and the new one as well (again, only bench reading). He will need to inject the original immo system into the new ECU firmware, then flash back to the new ECU. OBD2 reading won't work.
    It should work after that, I'm pretty sure that you'll need to use ODIS if the CP (component protection) has been triggered. You also may need adjust some coding using VCDS.
    If you want to tune the car after the ECU swap be aware that any tune done via OBD2 (virtual reading) it will brick the immo system. ALL the reading will need to be done on the bench and the original file need to be modified, than you can write back via OBD2 using your modified original file."
    The mentioned engine (CZD), if it's a CZDA, it does has phase timing on both cams and it should be fine using the harness and the ECU that came with and it doesn't has cylinder deactivation on it.
    More to come...
    Oct 2024
    Deventer
    Hello everyone. First of all, I would like to thank you for posting so much valuable
    information regarding to engine swap .
    I read everything very carefully and I am glad that there is hope for a solution to my problem that you were struggling with.
    I am also a recent owner of a mk7 variant 1.4 tsi caxa.
    unfortunately the engine seems to be in a tragic situation the oil consumption has drastically increased from month to month from one liter per 1000 now it is two liters..
    overall a tragedy, a cloud of smoke behind me .. I would like to fix it as best as I can and a general engine overhaul was supposed to be involved.the cost is high, of course, but I want to drive this car for a dozen or so years.. I like this Golf.. but when it comes to repairs, it is a temporary repair for a maximum of 100-150 thousand km and the problem returns.. that's what the mechanics assure me about this engine..
    I was already thinking about selling the car... when I was desperately looking for a solution and came across this post
    I am not a mechanic, I would like to take the car to a workshop to replace the engine, as in this post, I would like to switch from cxsa to czca and do everything to make the mechanic's life easier and speed up the engine replacement. According to what I have read, there is a lot of information here and it is hard for me to organize it, especially since I am just learning English :d
    I would like to make sure what parts to look for, exactly what fits, what doesn't, so that the engine replacement goes smoothly.
    information about the car from the service book version itd..
    BA5 4GX BA54GX VARIANT 1.4 HLBMT 90 KW MYF LC9X TW TSI M6F CXSA
    Oct 2024
    Deventer
    As for the engine, I can also look for an Audi Seat Skoda czca, are they the same units? As for the ecu, I have an older med 17.5.21 and I need a new med 17.5.25 and this one has to be from a Volkswagen, no matter what model? Is it best to look for an engine + ecu + engine harness from one car of course, however, available at this moment are younger engines with lower mileage, e.g. from Seat or Audi.
    can I buy an engine from a seat czcz and a separate ecu from volkswagen or is it better to look for a whole set from one car.. and as for the engine harness does it matter from which car and with what equipment? are they all the same or do they differ, e.g. one car has xeon lights the other halogen..
    I know that I have to buy an engine, ecu and engine harness , this is everything? Does the gearbox fit or are there other problems? I know there is a problem with the radiator fan, i have to move the cables in the plug, if I understand correctly, this should be done on engine harness from czca .
    I'm Sorry for so many questions I don't want to make a mistake when buying parts. I hope someone can help me with buying parts. Thank you and greetings to the owners who went through the swamp. This is my first swamp and I can't handle it myself so I'm asking for help. I asked in many workshops but they didn't do this swap I have to bring the engine ECU harness if it fits then I'll put it together and it will work .
    Best Regards Peter
    Jun 2018
    Quote Originally Posted by Peter3083 View Post
    Hi Peter,
    Not all workshops will be willing to do the swap, as they don't want to deal with the recoding and adaptations needed to make it work.
    I see that you're in Sydney, and Volks Mechanical can handle it for you. They’re crazy enough to do this kind of work, as well as other challenging swaps (like the DQ200 to DQ250 conversion in a certain wagon on this forum—spoiler alert). Rami and Tee will get everything sorted for you.
    Another option is to source everything from wreckers to keep costs down. You’ll need the following:
    • CZCA engine (92TSI) with the CZCA harness. The CZDA (110TSI) can also be used with the CZDA harness. These engines can be found in Mk7.5 Golfs, Tiguan 1.4s from 2017 onwards, and Audi A1, A3, and Q3 models (Rami and Tee can also make the more powerful CZDA engine work).
    • MED17.5.25 ECU from a VW, which is strongly advised as Audi uses a different IMMO scheme in their cars.
    If you can get all three from the same car, that would be ideal. The good news is that you can find low KMs engines at good prices. Once you have everything, you'll need someone to swap the engines, and Rami or Tee to code it all properly.
    Give them a call to discuss your options and costs.
    Hope that helps!
    Guto.
    More to come...
    Oct 2024
    Deventer
    Hi , Guto. Thank You for your valuable advice.unfortunately I am not in Sydney. I added one of the Australian cities to be able to register on the forum, but from what I see it is unnecessary. Sorry for misleading you.however I am trying to contact Volks mechanical. You are talking about adaptations, so are other adaptation procedures needed when it comes to the immobilizer? (adapting the counter etc.) I suspect that then the car must be physically in the garage to do this? I thought that I only need to download the immo data from my ecu from cxsa and transplant it to the donor ecu from czca. Then maybe I can organize it by sending them these two ecu 's
    there is a lot of work involved if it is not possible to arrange it remotely, shipping, I doubt I will find other specialists like you have in Australia. So far I have only found people who can do immo off at my place, but it does not satisfy me, I guess the car will start then, but the shining key from imo on the dashboard would not leave me alone, and in addition, my car might not be in front of my house in the morning after a night. if the idea with ecu does not work, it is also possible to replace the timing cassette, but is it really compatible with cxsa, or has anyone replaced it? Here, mechanics say that there may be other, not only the hpfp valve, but other millimeter differences in the shafts in the valve cover... tomorrow I will try to contact them from volks mechanical, the time zone makes it much more difficult for me xd
    Greetings, Peter
