Results 1 to 5 of 5
Thread: Any advice 2018 GTI , using more fuel than normal.
    Sep 2009
    Mernda, Vic
    Hey guys as the title states, I have 140k km on a manual unmodified 2018 GTI, until now every tank of fuel has gotten 620-650km per tank since new.
    The Last 3 tanks have been 500km. Seemed to happen over night.
    No codes on OBDeleven. Brakes are not sticking. I just did spark plugs and airfilter to see if that helped. Plugs wernt black so i figure not injectors, Tire pressures are fine.
    Any advice as to where i should start looking?
    Cheers, .
    Nov 2007
    I'd suggest cleaning the inlet manifold and ports from carbon buildup.
    Aug 2021
    I see where you're coming from, but it would seem rather odd that any carbon build-up would cause a sudden and significant change in fuel consumption in a relatively short space of time. The impacts of carbon build-up tend to be progressive over time, and not like flicking a switch.
    Personally, I'd be looking at the components that are part of the fuelling system and related sensors. A stuck injector, dodgy O2 sensor etc.
    Nov 2007
    Quote Originally Posted by petemac110 View Post
    I don't disagree with taking a good look at the fuel system and sensors as well, but at 140K km, it is already overdue that carbon will be a problem if it has't been cleaned yet.
    Carbon buildup does happen gradually, yes, but for quite a while, the buildup isn't enough to make a difference, and then suddenly, 1 day it is ... essentially, it reaches a tipping point where airflow is restricted beyond the abilities of the car to deal with it.
    The first step, though, should always be a full diagnostic scan, as injectors, O2 sensors, and FPR will normally throw some errors, which can help identify the cause.
    Sep 2009
    Mernda, Vic
    Update this is what i got after scanning while driving, now to research what it could be
    OBDeleven data log
    01 Engine
    System description: 2.0l R4 TFSI
    Software number: 5G0906259C
    Software version: 0002
    Hardware number: 06K907425B
    Hardware version: H13
    ODX name: EV_ECM20TFS0205G0906259C
    ODX version: 001005
    Long coding: 091900322444050B3000
    Trouble codes:
    P050700 - Idle Control System RPM Higher than Expected
    Intermittent
    P006800 - MAP/MAF - Throttle Position Correlation
    Intermittent
    U112300 - Databus error value received
    Intermittent
    Date: 2024-08-17 17:05:56
    Mileage: 140555 km
    Priority: 6
    Malfunction frequency counter: 2
    Unlearning counter: 255
    Engine speed: 903.00 1/min
    Normed load value: 14.1 %
    Vehicle speed: 0 km/h
    Coolant temperature: 79 °C
    Intake air temperature: 38 °C
    Ambient air pressure: 990 mbar
    Voltage terminal 30: 11.210 V
    Dynamic environmental data: 20961F41690000416A0001416B0000
    Intermittent
    P008800 - Fuel Rail/System Pressure - Too High
    Intermittent
    U012100 - Lost Communication With Anti-Lock Brake System (ABS) Control Module
    Intermittent
