The only real danger is you might flatten the battery if it isn't at 100% charge when you start (and recent Golfs often are not).
If I was doing it I'd connect to the -ve terminal on the battery first, then the +ve terminal, when I'm finished disconnect the +ve lead first, then the -ve.
