After a family member had the front bumper on a Golf 7 92tsi off to fix a parking sensor, the ACC radar had the same problem not being available.
Initially looking at the radar unit it was loose, after taking it apart and replacing in back into its mounting the radar unit was more stable. I adjusted the alignment as best as I could with a small levelling bubble on a dead flat surface. Took out the my OBD11 and under control unit 13 (ACC) there is a diagnostic mode which was easy to follow to reset the misalignment angle.
That was several months ago and the vehicle has been fine since. The physical alignment may be slightly out but no noticeable effect with driving.
Flipper Dog
Now - T-Roc R, Audi Q5
