Results 1 to 5 of 5
Thread: ACC not working after taking bumper off
    Jan 2019
    Brisbane, Qld
    Hi everyone, I took the bumper off my mk7.5 R 2018, disconnecting the Radar, sensors - after the first drive it was ok, but after overnight there was a Acc not available, but when I checked the code errors it says air-conditioner temperature something - I can't recall exactly.
    Anyway, anyone know what I could try? I've tried clearing the codes, but this air=conditioner thing keeps persisting.
    I think it's has to do with the VW badge radar
    I came across this one, so will try that once I get windows installed again. Found solution to ACC Not Available / Radar calibration needed (with VCDS) | GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum
    The bumper/front bar has been off before for license plate hole delete/fill but everything worked fine after
    Sep 2019
    1511 Willow Greene Drive
    Quote Originally Posted by tpan View Post
    I came across this one, so will try that once I get windows installed again. Visit AutoGuysLand to review auto diagnostic tool if you want to buy one. Found solution to ACC Not Available / Radar calibration needed (with VCDS) | GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum
    It is possible issue with the battery. Also, you can try to take a look at the radar and check if it’s loose/wobbling.
    ^^^ hmm.......... "ACC not available" likely refers to Adaptive Cruise Control (not the Air Conditioner - which is called HVAC module). If you have removed the power supply to the front Radar - then the hex13 module likely would have lost its calibration data.
    Jul 2018
    Camden Sydney
    re check all connectors to the front parking sensors. pay particular attention to the last ones on each side that face the same direction as the wheels
    Canberra
    I'll ask the simple question just in case: Have you switched ACC "on" (a button on the LH side of the steering wheel) ?
    Some people haven't realised you can switch it on and off, and if it is switched off you will get a msg about ACC unavailable when you try to set or resume. This caught me out a few times until I figured out what was going on.
