I removed the front bumper off my Mk7 GTI about a month ago. I have the optional ACC radar in the lower front grill. I just didnt disconnect the plug going to it - didnt have any issues. If you unplug it then you may need to have it recalibrated.
Hi,
Can anybody confirm if the ACC will require re calibrating once it has been disconnected due to a front bumper removal on a 7.5R ? - Mixed responses online.
Thanks
Thanks for your response.
I’ll see if I can leave the radar connected. Mine is connected to the upper grill for the 7.5. I just need the front bar off in order to install a splitter.
Cheers mate 👍
I've disconnected the radar twice and both times I didn't recalibrate it. I haven't noticed any problems and it seems to function as before - still keeping a fair distance from the car in front with the closest setting available.
Good advice about not needing to disconnect it though. I might not have disconnected it if I knew I didn't have to.
2016 MK7 Golf GTI 40 Years | White | DSG | UGP Stage 2 | IE Downpipe | XForce Varex Catback | Mishimoto Intercooler | Forge Turbo Blanket | Forge Turbo Intake Pipe | Gentleman's Intake Mod | K&N Air Filter | BMS Turbo Muffler Delete | GFB DV+ (T9359) | Eibach Lowering Springs | Superpro LCA | 034M Complete Dogbone Mount Replacement | 034M Rear Sway Bar | 034M Rear Endlinks | Whiteline Front Sway Bar | Whiteline Front Endlinks | Whiteline Roll Centre Kit | OEM+ Full Aero Kit | Audi RS3 Brake Ducts | Power Folding Mirrors | Various VCDS Tweaks
