Results 1 to 10 of 14
Thread: 7.5 R Special Edition - Clicking noises from fron the fron wheels
    Mar 2019
    Picked up the 7.5R Special Edition in Jan, and then had the stage 1 done and lowered with the Eibach pro springs and 26mm rear sway bar fitted in less than 500kms on the clock.
    Recently I have noticed there are constant clicking noises coming fron the front wheels while I am driving with the windows down. It especially noticable when driving next to parked cars, walls or barriers which echos the sound back. I start hearing the noises above 40km/h. Firstly, I though it would be something stuck in the tyres but I couldn't find anything. Then I found out the noise is gone while I pushing the brakes. I not sure thats because the special edition is fitted with the cross-drilled discs.
    Sent back to the mechanic who fitted the springs and the dealer, both could not solve the problem. The funniest thing is the dealer was saying the clicking noises is coming from the DSG and found this to be a characteristic of the DSG.
    I am pretty sure it's not the DSG making the clicking noises. Has anyone had the same problem? Does it have anything to do with the lowering? I am not 100% sure the noise was there before lowering the car. My friend had 7.5 without the cross-drilled discs and exact same setups as mine and after I told him the nosie, he started to notice it too lol.
    Any one can help?
    Feb 2018
    Quote Originally Posted by guilinpan View Post
    Any one can help?
    Welcome and congrats on getting an SE.
    If you scrolled a little further in the forum you would of found this thread -
    2018 Golf R Performance Edition - wheel clicks
    I have had one side replaced under warranty and it worked with clearing the clicking sound.
    Sent from my SM-N950F using Tapatalk
    Mar 2019
    Thanks grugly, so did they replaced the bearing or the cv joint? How did you get them to replaced it?
    Feb 2018
    Went to the dealership service team. Took the head tech out and showed him the sound. Mentioned someone else had replaced the wheel bearing and it didn't work so they replaced the strut bearing? He said what was replaced doesn't normally make that sound so it had them a bit baffled.
    Feb 2018
    I'm waiting on doing the other side before I get the final paperwork so will be able to explain it better once that happens.
    Mar 2019
    Quote Originally Posted by Grugly View Post
    have you replaced the other side yet grugly? any news on that?
    Feb 2018
    Not yet, as I had an incident with a roo.. should be in the next week or two
    Mar 2019
    Damn.. freakn roosss. hope nothing major.
    Jan 2015
    Got the same issue. Same symptoms. Did you find a resolution for it? Thabks
    Jan 2015
    Mine is stock. No changes to anything
