Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 55
Thread: 1.4L 118kw engine GONE
    Jan 2008
    Sunshine Coast
    All that said if it wasn't for me seeing a twincharge engine on display at Sydney airport back in 2008, it's unlikely I would have a VW now. Reliable or not, I still adore it as an engineering feat, and remains my basis for future projects!
    Trinidad and Tobago
    Quote Originally Posted by Lima View Post
    Yep, the comments here tell a pretty sorry tale...
    http://www.ausmotive.com/2009/02/01/...#comment-block
    Most if not all of those comments are for 2009-2010 engines. The reliability has gone way up since then. I'm more worried about the dq200!
    Oct 2010
    Melbourne, VIC
    Check out the 6R Polo section for issues with the GTi which uses a tuned up version of the TwinCharger - compression loss and/or 2-stroke like oil consumption requiring pistons & rings or total engine replacement.
    VW are ditching this design for good reasons.
    Resident grumpy old fart
    Sunshine coast
    The 1.8L 118TSI in the Passat is a different engine though?
    132TSI Tiguan Allspace
    Canberra
    Quote Originally Posted by iampivot View Post
    Yes, it's not a twincharger.
    Feb 2008
    I ditched my 118tsi as soon as the first engine was replaced. Paid 36k for it, got 18k back at year later. I'm probably lucky I only lost half it's value...
    Aren't the 1.4 T engines in the new Golf a major overhaul on the 1.4T (90kw) in the current Golf range? So in effect none of the 1.4L engines of the MK6 made it to the MK7.
    There is a new CTHE version of the twincharger engine for the Polo GTI/Fabia VRS coming out in Sept. So it is hardly dead yet.
    If you are trying to strip weight from a car you are hardly going to stick the heavy twincharger engine in it for a 15kw benefit (over the 103kw 1.4T).
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by woofy View Post
    Skoda were smart to not use that engine and keep the older version....
    See the above post about Skoda's use of the TwinCharger..
    Sunshine coast
    Quote Originally Posted by ziggyboy View Post
    I thought TSI stood for twin charger?
    Jan 2009
    It would appear that the T in TSI can either stand for turbo(charged) or twincharger/twincharged, depending on the configuration.
