Hi guys
There's a lot of talk (and heated discussion I've seen) on various forums as to what our FREE DSG light-tune entails and what it's affects are so I thought to save the arguments I'll tell anyone wanting to know how it works, on here.
We offer full direct DSG ECU tuning and indirect dsg tuning on certain vehicles.
Viezu has developed an amazing range of DSG Gearbox tuning services. The DSG gearbox tuning carried out is an excellent compliment to Viezu’s ECU remapping and engine tuning services. Just like our range of ECU remapping tuning, each DSG Gearbox tuning file is written specifically for the vehicle and driver that it is intended for, the DSG Gearbox tuning can be custom tailored to the driver's and vehicle's requirements – each file can include launch control, shift and torque limiter functions and setting adjustments to give you the ultimate driving experience.
Light modifications to the DSG gear box can be made to improved shift speed, responsiveness, smoothness and alterations in launch control - and even if you are not a track day driver, all drivers will enjoy these changes.
For more demanding and “spirited” drivers we can go further custom with our DSG gearbox tuning. This is highly suitable for modified and tuned vehicles, as well as the custom engine tuning we offer, the dsg gearbox tuning can ensure your engines performance and vehicles modifications are really working in harmony with your gearbox, i.e. performance exhausts, cats, (or de-cat), DPF deletions, supercharger and turbo upgrades can all be brought to life.
With fully custom DSG Gearbox tuning, including launch control, torque settings and enhanced shift points to suit your vehicle set up the difference after tuning will be dramatic, making the use of your DSG so much more superior and much closer to a track experience and performance.
Custom DSG Software Tuning with Viezu :
Increased Shift Response:
The shift response has been increased by up to 20% giving a smoother transition, leading to a decrease in unnecessary clutch slippage under full load accelerations, which reduces clutch wear.
With increased shift time you also get an improved paddle-reaction-time by up to 40% in S-mode.
Torque Limit Increase:
On normal straight engine remaps torque limits are normally changed as part of engine tuning, but if your gear box is not tuned too, you are missing out! (Although uniquely as part of our indirect free-light-dsg-tunes for certain vehicles this is also altered on the engine ecu tune by very clever understanding and alterations affecting the complex DSG coding. This leads to faster, smoother shifts, better responses, faster pick up and removes hesitation whilst also altering the LC function)
Through tuning the DSG Gearbox's ability to transmit torque from 350 Nm up to 550 Nm while still ensuring the stability and capability of all the mechanical moving hardware within the DSG gearbox. Torque limit both with our engine ecu tuning and now DSG is custom tuneable to your specification.
Increased Red Line:
Again, just like torque limiter tuning, its no good changing your engine rpm, if your gear box too is limited, now with our DSG tuning, all components can work in perfect harmony.
Increasing the shift points gives you the command of your engine's power in the upper RPM range; we have raised the DSG transmission's rev limit to work with your engine's new power and tuning.
Launch Control:
With Viezu’s Direct DSG tuning launch control can be activated on most vehicles.
A perfect launch can now be achieved releasing maximum 0-100 acceleration.
If you are looking to take your tuning to the next level, and bring all your modifications and engine tuning in harmony with your gearbox, DSG Gear box tuning is here.
And like all Viezu tuning and performance products DSG tuning comes with our no quibble 30 day money back guarantee and insurance.
Happy to answer any queries you may have on this Viezu main forum area so please fire away with any queries at all.
Simon
So, The DSG Gearbox can be installed in any car or it is limited to some fixed car models or company only?
