Results 11 to 20 of 22
Thread: Forge quick shift fits 9N3 GTI, some MK4 chassis and some MK5 and 6, 6 speed manuals.
    May 2011
    Albury, NSW
    Do you know if this fits 02A boxes - they say early VAG 5 Speed - so you'd assume so, but there's no mention of VR6 etc. I already have one, just never installed it, was gonna put it in the MK1. I was thinking of doing the 02J shifter converstion anyways.
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
    Nov 2012
    Gav how does this work with 9n3? Install instructions show a ball and socket, mine has a straight shaft for the shift cable?
    Quote Originally Posted by Bullet Fast View Post
    Comes with 3 different pins, one of which is the right one.
    gavin
    Nov 2014
    Sorry to be dumb but is the s3 8l the AGU box?
    Quote Originally Posted by jgribben View Post
    No it isn't mate. AGU is the code for the engine in the MK4 GTI over here. Forge Motorsport Adjustable Quick Shifter for VAG 6 Speed Models > Transmission > A3 8L 1996-2003 > AUDI A3/S3 > VW Specialists > PSI Tuning - VW Audi Specialists there is one that will fit your gearbox. I am going to put in an order this week if you want, I can add one to the order for you.
    Nov 2014
    dunno. I was pretty keen on the diesel geek one up until now have you tried both and recommendation? my gearbox is starting to feel a little loose on (bit of left right movement when its in gear) was going to see if a short shift would help a bit and a bit of an upgrade while I'm there.
    I doubt you would come across many that have tried Forge and Diesel Geek on the same car. There's nothing wrong with the one for the polo.
    It depends where the slack in your gearchange is, most likely neither will fix worn out linkages.
    Oct 2014
    I'd be keen if you get some in.
    I'll put one on the next order for you Jack.
