GSL RallySport and Brakes Direct stocks the complete range of Project Mu disc rotors!
STREET SPORTS
Project Mu CRD Disc Rotor
The new Project Mu rotor for the entry level customer looking to improve the look and performance of standard brake packages. The CRD rotors are vented and slotted.
Structure - 1 Piece
Material - FC Cast Iron
Slots - 8 directional straight
Project Mu Pure Plus 6 Disc Rotor
This rotor is designed as a Top quality OE replacement part.
It is an economical option to replace your standard rotors for a higher quality component with slots for better performance. These slots are directional and the curved design is for low noise which is suitable for your road car.
The cooling vane design of the SCR Pure Plus 6 rotor is very similar to OEM designs. This is a design that is economical to manufacture and provides sufficient ‘rotor mass’ to handle all road conditions. This means you get an improvement from OEM, but at the right cost.
Manufactured in Japan using top quality cast iron to Project Mu specifications, these rotors are ideal for your street car.
Structure - 1 Piece
Material - FC cast iron
Slots - 6 Curved Slots
Project Mu SCR Disc Rotor
The SCR rotor is designed to be a cross over from high performance street to track. It is made from high-carbon and alloy cast iron and has an excellent structural qualities resulting in a very stable rotor. The vane design allows large volumes of air to pass through offering more stable disc performance at the higher temperatures seen on the track.
Along with this, the straight slot (xdesign offers high resistance to fade making this disc ideal for track use, drifting, rally and any high performance application.
Structure - 1 Piece
Material - High Alloy FC Cast Iron
CLUB RACING
Project Mu SCR Pro Disc Rotor
The premium rotor in the Project Mu range, the SCR-Pro incorporates all features you will find in a race rotor – packaged to fit onto standard cars.
The cast iron has very high levels of carbon and alloy, 8 straight slots and an advanced core vane design resulting in very high heat transfer qualities. Additionally, the SCR-Pro is a two-piece design that comes assembled to anodized billet alloy disc hats making them lighter than EOM rotors.
The SCR Pro employs motorsport experience and technology that provides the highest possible heat transfer properties of all Project Mu rotors. The vanes are designed to create additional turbulence inside the rotor without compromising air flow which in turn transfers more heat from the rotor to atmosphere.
The disc itself is completed in black chrome to further increase life and resistance to distortion. Ideal for race, rally and drift applications or simply as a premium upgrade to your road car.
Structure - 2 Piece
Rotor - Carbon/Alloy Iron
Hat - Billet Aluminium
Project Mu SCR GT Disc Rotor
SCR-GT uses SCR-Pro rotors and technology with the addition of floating mounts. The floating system is used in motorsport applications to allow the rotor to move independently of the bell / hub which allows some movement at temperature.
The cast iron has very high levels of carbon and alloy, 8 straight slots and an advanced core vane design resulting in very high heat transfer qualities. Additionally, the SCR GT is a two-piece design that comes assembled to anodized billet alloy disc hats making them lighter than EOM rotors.
The SCR GT employs motorsport experience and technology that provides the highest possible heat transfer properties of all Project Mu rotors. The vanes are designed to create additional turbulence inside the rotor without compromising air flow which in turn transfers more heat from the rotor to atmosphere.
Structure - 2 Piece
Hat - Floating - Billet Alloy
For more information or to purchase any Project Mu Disc Rotor, contact the following distributors:
GSL RallySport
Ph: 1300 884 836 (within Australia)
Ph: +617 3188 7534 (International)
Email: sales@gslrallysport.com
Web: GSL RallySport... The Motor Sport Revolution!
Address: Unit 5 / 14 Buttonwood Place, Willawong QLD 4110
Brakes Direct National Offices
Ph: 1300 724 943 (within Australia)
Ph: 09 951 5726 (within New Zealand)
Email: sales@brakesdirect.com.au
Web: Brakes Direct
Brakes Direct State Branches
North QLD - Ph: (07) 4422 0303
South East QLD - Ph: (07) 3177 0806
NSW - Ph: (02) 9191 9387
ACT - Ph: (02) 6171 2025
VIC - Ph: (03) 9938 8221
TAS - Ph: (03) 6111 0500
SA - Ph: (08 ) 7070 1402
WA - Ph: (08 ) 6500 0151
NT - Ph: (08 ) 7999 7400
GSL RallySport 1300 884 836
Sick of paying too much for performance brake pads? Want high performance with low rotor wear?
QFM Performance Pads
