GSL RallySport and Brakes Direct stocks the complete range of Queensland Friction Material (QFM) disc brake pads, from OEM and standard replacement, right through to the HPX and A1RM street, performance and track brake pads!
QFM Super X Brake Pads
Super X is the ideal disc brake pad to handle a wide range of driving conditions and is recommended for most passenger vehicles. Braking is made easy with great pedal feel even when the brakes are cold.
Other features of Super X that many drivers prefer is long wear life, low dust, low noise and that they are kind on the disc rotors resulting in low rotor wear. Temperature Range 0-470 degrees Celsius.
N Brake ECR Brake Pads
N Brake ECR is a general purpose semi-metallic disc brake pad that is suitable for a wide range of vehicle applications and driving conditions. ECR has low dust, long life and extended disc rotor wear.
Manufactured in Thailand, N Brake meets the extremely high quality performance measure of being, ISO9001:2008 and ISO TS16949:2009 certified. This ensures consistency in quality and performance.
QFM is proud to be the exclusive distributor of N Brake in Australia. Temperature Range 0-400 degrees Celsius.
QFM Taxi 69 Brake Pads
Taxi 69 is designed especially to meet the demands of taxi operations. When taxis are on the go they generate constant high temperature with very little chance to cool down. These conditions can often result in rapid wear of the brake pad and in some cases, loss of braking efficiency.
Taxi 69 can handle the constant high temperature conditions yet still provide responsive braking and pedal feel. Taxi operators enjoy the long life and low disc rotor wear and have made Taxi 69 one of the leading brands used by the industry. Temperature range 0-480 degrees Celsius.
QFM 4WD Brake Pads
4WD vehicles are often a lot heavier than the normal passenger vehicle, resulting in the demand on the brake pads being greater. QFM 4WD is able to handle the heat generated by the extra weight and still provide excellent pedal feel and responsive braking.
Standard brake pads in many 4WD applications will not measure up to the extra heat which can result in loss of braking efficiency. 4WD is not a dusty pad and is kind to the disc rotors.
It is the preferred brand fitted and recommended by many Brake Repair Specialists for 4WD vehicles. Temperature range 0-540 degrees Celsius.
QFM HPX Brake Pads
HPX is a heavy duty brake pad that is recommended for performance, passenger and trade vehicles. These vehicles can often generate high temperatures yet they still require a brake pad to handle normal, everyday conditions.
Excellent pedal feel combined with great stopping power hot or cold makes HPX the ideal brake pad for these vehicles. Other features of HPX that motorists enjoy are low dust, low disc rotor wear and quiet operation of the pads. Temperature range 0-550 degrees Celsius.
QFM A1RM Brake Pads
A1RM is a high performance street pad that is also suitable for light track and rally work. This pad is designed to meet the temperatures generated by heavy and prolonged braking applications. A1RM has very good cold effectiveness and pedal feel.
Due to the performance and frictional attributes of A1RM, some vehicles experience higher dust and wear rates than standard disc pads. This is the ideal pad for the enthusiast who wants to combine performance braking at the track with normal braking demands without having to change pads. Temperature range 0-780 degrees Celsius.
QFM BRAKE PAD BED IN PROCEDURE CAN BE FOUND HERE!
For more information or to purchase any set of QFM Brake Pads, contact the following distributors:
GSL RallySport
Ph: 1300 884 836 (within Australia)
Ph: +617 3188 7534 (International)
Email: sales@gslrallysport.com
Web: GSL RallySport... The Motor Sport Revolution!
Address: Unit 5 / 14 Buttonwood Place, Willawong QLD 4110
Brakes Direct National Offices
Ph: 1300 724 943 (within Australia)
Ph: 09 951 5726 (within New Zealand)
Email: sales@brakesdirect.com.au
Web: Brakes Direct
Brakes Direct State Branches
North QLD - Ph: (07) 4422 0303
South East QLD - Ph: (07) 3177 0806
NSW - Ph: (02) 9191 9387
ACT - Ph: (02) 6171 2025
VIC - Ph: (03) 9938 8221
TAS - Ph: (03) 6111 0500
SA - Ph: (08 ) 7070 1402
WA - Ph: (08 ) 6500 0151
NT - Ph: (08 ) 7999 7400
GSL RallySport 1300 884 836
Sick of paying too much for performance brake pads? Want high performance with low rotor wear?
QFM Performance Pads
Don't take our word for it... here's what happy drivers have to say about the QFM HPX!
Writeup: QFM A1RM Brake Pads from GSLRALLYSPORT - Page 2I just got back from a trip down the coast N.S.W did a 1000kms on the QFM HPX pads with the slotted rotors supplied from GSL and have to say zero dust. The car needed a wash not the rims for a change. I felt it brakes better than the stock pads. Also half the price of a stock set up and got slotted all round!
The Australian 300zx Owners Association - View Single Post - Brake Pads......I have been running the HPX on the front of the convertible for a couple of months now. I have not noticed any dust and the difference to whatever pads were there before is that they perform near 100% from the very first application!
QFM Brake Pads - Page 2Got the pads put on today....freaking awesome man. I'll be highly recommending these to anyone who asks. The cold bite and the amount of speed it wipes off is just awesome!
QFM Brake PadsI put a set of QFM HPX front and Super X on the rear of my GF's twin turbo soarer and **** ME! The car stops so well! this was installed with RDA slotted rotors purchased from GSL RallySport. Great service, great products, recommend to anyone, and will be buying anything else i need from here!
