Results 1 to 3 of 3
Thread: Bendix Brake Pads
    Bendix Brake Pads
    Brakes Direct - Bendix
    Bendix is Australia’s leading brake manufacturer since 1955, and is part of the international FMP Group (Friction Materials Pacific) who is a world leader in brake technology. FMP’s Australian manufacturing operation is the regional technical centre of excellence in advanced research and development for Asia Pacific and a key original equipment supplier to leading vehicle manufacturers. Bendix caters for a wide range of automotive applications, including 4WD’s and heavy commercial vehicles and trailers with advanced Bendix products such as General CT, 4WD, Heavy Duty, Ultimate, Brake Shoes, All Passenger, Truck and Trailer, Brake Lubrication, Brake Fluid and Brake Parts Cleaning.
    Bendix’s manufacturing plant in Victoria has gained a reputation of manufacturing, marketing and distributing quality products. Bendix’s affiliation with one of the world’s largest friction materials manufacturers, such as FMP and Honeywell Friction Materials, gives the company access to the latest friction material technology and techniques. This technology base, together with its strong global links, gives Bendix the ability to tailor friction solutions for all customer applications.
    Hybrid Fusion Technology is an innovative combination of Bendix braking science and engineering that generates advanced friction performance through the fusion of the complete range of Bendix innovations. Hybrid Fusion Technology integrates different compound combinations that are formulated at a molecular level to determine how the brake pad material is structured with Stealth Advanced Technology, Blue Titanium Stripe, and Fibre Impregnated Rubber Steel Shims into one innovative product. This advanced technology results in improved wear life of brake pads and rotors, improved green friction and reduced brake fade, and OE stopping power with quieter braking and smoother performance.
    Driving style and type of vehicle greatly affect brake pad performance. The key to excellent braking is matching the driving style and vehicle with the right brake pad formulation. You can select and fit the right Bendix brake pad for virtually every application with absolute confidence.
    Available from:
    Brakes Direct
    National Offices
    • Australia - 1300 724 943
    • New Zealand - 09 951 5726
    State Offices
    • North QLD - (07) 4422 0303
    • South East QLD - (07) 3177 0806
    • NSW - (02) 9191 9387
    • ACT - (02) 6171 2025
    • VIC - (03) 9938 8221
    • TAS - (03) 6111 0500
    • SA - (0 7070 1402
    • WA - (0 6500 0151
    • NT - (0 7999 7400
    GSL RallySport 1300 884 836
    Sick of paying too much for performance brake pads? Want high performance with low rotor wear?
    QFM Performance Pads
    Pacific Paradise QLD
    Would be nice seeing as you are posting this on a VW forum you could perhaps include some more of our models as well.
    Do you know how many different variants of pad shapes there are for VW? That is as open ended of a question as you can possibly ask. Your application will also determine the compound we supply, and Bendix dont make all of there compounds for a lot of there listings.
    If you would like a price on a set of pads, please send us the full vehicle details including the VIN and what the car is being used for.
    Regards Matt
