OMG. So cheap! Someone pick up a bargain!
Hi all,
Got 1 set available each for Mk3 and Mk4 Golf, 40mm DMS coilovers including springs. DMS aren't pretend toy suspension like what you buy on Ebay, it's suspension that wins Targa events and gravel rally championships. The 40mm is their entry level high performance street/circuit coilovers, and are bump/rebound adjustable (combined).
List/Retail price is $3586 per car set including springs. We've got 1 car set of each $2249 including springs, freight and GST.Due to strong demand DMS introduced in 2003 the DMS Gold, 40mm performance street range of shock absorbers.
This is a bump/rebound adjustable shock with a wide, useable range of adjustment giving users 30 settings allowing for all applications, from comfortable touring to club motor sport.
DMS Gold 40mm adjustable shock absorber is made for a wide range of vehicles, including Subaru Impreza, Mitsubishi Lancer, Mirage, VW and many others. Check our website catalogue or with your DMS distributor for shocks for your car.
DMS Gold 40mm shock absorbers have high flow piston ports giving this shock superior control allowing more precise tuning.
Consult your DMS dealer on other parts which will help get the best from your DMS Gold 40mm Shocks. These may include sports shock and suspension mounts. These products are available for most performance cars. (Some stock suspension bushes allow excessive suspension movement not controlled by the shock or spring.)
Product Description:
DMS blue shell case. Made of chrome-moly high strength steel. Fitted with adjustable anodized aluminum spring seat and lock nut. The DMS 40mm strut body is fitted with double lipped seals at the top, special low friction bushes and a seal below bottom bush to eliminate stiction. DMS uses specially formulated grease which gives durability and longevity to the 40mm GOLD suspension
Adjustable camber available on mounting brackets.
40mm shock absorber insert with high flow competition design piston with 30 defined adjustable bump and rebound settings.
DMS only use special formulated racing shock absorber fluid in this street performance product.
Any questions feel free to give us a bell on 1300 884 836.
Regards,
Greg
GSL RallySport 1300 884 836
Sick of paying too much for performance brake pads? Want high performance with low rotor wear?
QFM Performance Pads
Nothing to see here...
No takers?!
