Click HERE to order or for more information.
Front/Rear 2-Piece Brake Rotors For VW MKV R32 - Starting At $399.95!
The MKV R32 proved to Volkswagen skeptics that the Golf platform is a capable race-bred engineering overhaul. Volkswagen did however commit a serious oversight when addressing the MKV's braking arrangement. A heavy single-piece, non-floating rotor design was installed from the factory.
ECS Tuning designed the part that should have come from the factory - lightweight two-piece, semi-floating, cross-drilled & slotted brake rotors with hard-anodized aluminum hats. They act as a heat and stress buffer, and create a weight savings of 30% in the front and 15% in the rear - per wheel!
