Click HERE to order or for more information.
VW MKV R32 Ziza License LED Kit - $49.95 *
Ziza lighting is proud to introduce LED license plate bulbs for the MKV that will not throw a bulb out code. These lights are direct replacement bulbs that install in minutes, there is no need to wire up fancy resistors or hack your factory wiring to get these to work.
Simply remove your plate light assembly, and replace the factory incandescent bulb with our Ziza bulb. When installing bulbs, be sure to place the end with the large heat sink pointing upwards, this makes sure the brightest part of the LED will be shining down on your license plate.
*Free shipping applies to orders shipped within the contiguous U.S. only.
