Click HERE to order or for more information.
VW MKV Jetta 2.0T ECS 6-Speed Clutch Bleeder Block - $109.95!
Engineered by our R&D team, this new product addresses limitations of the plastic OE part. Its larger internal fluid passage increases flow for fast clutch engagement and release. To reduce flex and heat distortion, the new block uses no plastic whatsoever, replacing it with a solid block of machined aluminum, black anodized for hardness and corrosion protection. One look shows the added value of the new design; a test drive confirms it.
