Click HERE to order or for more information.
Timing Service Kits for your VW B6 Passat | EOS -
A broken timing belt does more than leave you in tennis shoe mode; it causes extensive expensive engine damage when piston heads mangle valves.
Don't wait for disaster to strike. Check our assortment of timing belts and belt kits. We have you covered: from basic belt-tensioner combos to Ultimate kits with water pump, thermostat, accessory belts, bolts, seals, and ECS lightweight pulleys.
ECS: we have what you need to get it done.
