Click HERE to order or for more information.
VW MK7 Golf/GTI ECS Big Brake Kits -
The ECS MK7 Big Brake Kit completely transforms your braking system and stopping experience. The kits utilize the larger rotors from the MK5 R32, which are 345x30mm in the fronts and 310x22mm in the rear.
Kits are available with ECS 2-piece semi-floating, slotted and cross drilled rotors for optimum heat and water dispersion, as well as increased stopping power and maximum weight savings over a standard one piece rotor.
The ECS custom made, stainless steel brake lines complete the installation for 100% bolt on performance.
