Click HERE to order or for more information.
VW MK5 Jetta TDI Clutch Upgrades -
Here are some frictional characters you can believe in.
ECS Tuning clutch kits let you restore the smooth clutch operation and performance you expect from your manual transmission.
Knowing that one size can't possibly fit all, we've gone out of our way to give you the choices you want. From single mass flywheel conversions that replace your failure prone dual mass flywheel to all out performance upgrades rated at 600+ ft/lbs. you're sure to find the clutch kit that suits your needs, and exceeds your expectations.
If your clutch has swapped grip for slip, order soon.
