Click HERE to order or for more information.
VW ECS MK4 R32 ECS Intake & Catch Can Systems -
More air means more power - it's for this simple reason that an easy-to-install performance intake from ECS should be first on your list of engine upgrades for your R32.
The putative principle behind a cold air intake is that cooler air has a higher density, thus containing more oxygen per volume unit than warmer air.
To help reduce unintended ingestion of oil vapor and carbon into the intake tract, the ECS Baffled Oil Catch Can utilizes a highly efficient 4 chamber oil separator that significantly improves oil/air separation - restoring engine power and efficiency.
